Datasheet BZX55 (Vishay) - 2
Manufacturer | Vishay |
Description | Small Signal Zener Diodes |
Pages / Page | 7 / 2 — BZX55-Series. ELECTRICAL CHARACTERISTICS. ZENER VOLTAGE. TEST. REVERSE … |
File Format / Size | PDF / 104 Kb |
BZX55-Series. ELECTRICAL CHARACTERISTICS. ZENER VOLTAGE. TEST. REVERSE LEAKAGE. DYNAMIC. TEMPERATURE. RANGE. CURRENT. RESISTANCE
BZX55-Series
(Tamb = 25 °C, unless otherwise specified)
ZENER VOLTAGE TEST REVERSE LEAKAGE DYNAMIC TEMPERATURE RANGE CURRENT CURRENT RESISTANCE COEFFICIENT IR at VR ZZ at IZT1 ZZK at IZT2 PART NUMBER VZ at IZT1 IZT1 IZT2 TK T T VZ amb = amb = f = 1 kHz 25 °C 150 °C V mA μA V
Ω
%/K MIN. NOM. MAX. MAX. MAX. MIN. MAX.
BZX55C2V4 2.28 2.4 2.56 5 1 < 50 < 100 1 < 85 < 600 - 0.09 - 0.06 BZX55C2V7 2.5 2.7 2.9 5 1 < 10 < 50 1 < 85 < 600 - 0.09 - 0.06 BZX55C3V0 2.8 3.0 3.2 5 1 < 4 < 40 1 < 85 < 600 - 0.08 - 0.05 BZX55C3V3 3.1 3.3 3.5 5 1 < 2 < 40 1 < 85 < 600 - 0.08 - 0.05 BZX55C3V6 3.4 3.6 3.8 5 1 < 2 < 40 1 < 85 < 600 - 0.08 - 0.05 BZX55C3V9 3.7 3.9 4.1 5 1 < 2 < 40 1 < 85 < 600 - 0.08 - 0.05 BZX55C4V3 4 4.3 4.6 5 1 < 1 < 20 1 < 75 < 600 - 0.06 - 0.03 BZX55C4V7 4.4 4.7 5 5 1 < 0.5 < 10 1 < 60 < 600 - 0.05 0.02 BZX55C5V1 4.8 5.1 5.4 5 1 < 0.1 < 2 1 < 35 < 550 - 0.02 0.02 BZX55C5V6 5.2 5.6 6 5 1 < 0.1 < 2 1 < 25 < 450 - 0.05 0.05 BZX55C6V2 5.8 6.2 6.6 5 1 < 0.1 < 2 2 < 10 < 200 0.03 0.06 BZX55C6V8 6.4 6.8 7.2 5 1 < 0.1 < 2 3 < 8 < 150 0.03 0.07 BZX55C7V5 7 7.5 7.9 5 1 < 0.1 < 2 5 < 7 < 50 0.03 0.07 BZX55C8V2 7.7 8.2 8.7 5 1 < 0.1 < 2 6.2 < 7 < 50 0.03 0.08 BZX55C9V1 8.5 9.1 9.6 5 1 < 0.1 < 2 6.8 < 10 < 50 0.03 0.09 BZX55C10 9.4 10 10.6 5 1 < 0.1 < 2 7.5 < 15 < 70 0.03 0.1 BZX55C11 10.4 11 11.6 5 1 < 0.1 < 2 8.2 < 20 < 70 0.03 0.11 BZX55C12 11.4 12 12.7 5 1 < 0.1 < 2 9.1 < 20 < 90 0.03 0.11 BZX55C13 12.4 13 14.1 5 1 < 0.1 < 2 10 < 26 < 110 0.03 0.11 BZX55C15 13.8 15 15.6 5 1 < 0.1 < 2 11 < 30 < 110 0.03 0.11 BZX55C16 15.3 16 17.1 5 1 < 0.1 < 2 12 < 40 < 170 0.03 0.11 BZX55C18 16.8 18 19.1 5 1 < 0.1 < 2 13 < 50 < 170 0.03 0.11 BZX55C20 18.8 20 21.2 5 1 < 0.1 < 2 15 < 55 < 220 0.03 0.11 BZX55C22 20.8 22 23.3 5 1 < 0.1 < 2 16 < 55 < 220 0.04 0.12 BZX55C24 22.8 24 25.6 5 1 < 0.1 < 2 18 < 80 < 220 0.04 0.12 BZX55C27 25.1 27 28.9 5 1 < 0.1 < 2 20 < 80 < 220 0.04 0.12 BZX55C30 28 30 32 5 1 < 0.1 < 2 22 < 80 < 220 0.04 0.12 BZX55C33 31 33 35 5 1 < 0.1 < 2 24 < 80 < 220 0.04 0.12 BZX55C36 34 36 38 5 1 < 0.1 < 2 27 < 80 < 220 0.04 0.12 BZX55C39 37 39 41 2.5 0.5 < 0.1 < 5 30 < 90 < 500 0.04 0.12 BZX55C43 40 43 46 2.5 0.5 < 0.1 < 5 33 < 90 < 600 0.04 0.12 BZX55C47 44 47 50 2.5 0.5 < 0.1 < 5 36 < 110 < 700 0.04 0.12 BZX55C51 48 51 54 2.5 0.5 < 0.1 < 10 39 < 125 < 700 0.04 0.12 BZX55C56 52 56 60 2.5 0.5 < 0.1 < 10 43 < 135 < 1000 0.04 0.12 BZX55C62 58 62 66 2.5 0.5 < 0.1 < 10 47 < 150 < 1000 0.04 0.12 BZX55C68 64 68 72 2.5 0.5 < 0.1 < 10 51 < 200 < 1000 0.04 0.12 BZX55C75 70 75 79 2.5 0.5 < 0.1 < 10 56 < 250 < 1500 0.04 0.12 Rev. 1.8, 25-Nov-2021
2
Document Number: 85604 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
