Datasheet AP43776Q (Diodes) - 10
Manufacturer | Diodes |
Description | Automotive-Grade Dual-Channel USB Type-C Protocol Decoder |
Pages / Page | 13 / 10 — AP43776Q. Electrical Characteristics. Symbol. Parameter. Condition. Min. … |
File Format / Size | PDF / 973 Kb |
AP43776Q. Electrical Characteristics. Symbol. Parameter. Condition. Min. Typ. Max. Unit. VCC PIN & INTERNAL BIAS SECTION
AP43776Q Electrical Characteristics
(-40°C < TA< +125°C , VCC = 5V, unless otherwise specified.)
Symbol Parameter Condition Min Typ Max Unit VCC PIN & INTERNAL BIAS SECTION
VCC_OP VCC Operation Range — 3 — 5.5 V VCC_POR VCC Power-on Reset Voltage — 2.0 — 3.1 V VCC_POR HYS VCC Power-on Hysteresis — — 0.1 — V ISM Sleep Mode Current VCC = 5V @ sleep mode 150 — 1200 μA ICC_OP Operating Supply Current — 1.1 — 3.0 mA IS_SCL Sink Current of SCL for impedance check VSCL = 1V 760 840 920 μA V2V Internal Reference Voltage 2.046±5% 1.944 2.046 2.148 V CLK12M Internal Clock Frequency 12MHz±10% 10.8 12 13.2 MHz
CC1/CC2 PIN SECTION
VOH_open Pull High Voltage of CCx — 3.4 3.6 3.8 V Irp_330 Source Current of CCx RD = 5.1KΩ 305 330 355 μA VSW_TxDC Voltage Swing of CCx for BMC Tx RD = 5.1KΩ 1.05 1.125 1.2 V VSW_TxDCL Low Voltage Swing of CCx for BMC Tx RD = 5.1KΩ 0 -- 75 mV RVCONN Rds_on of internal Vconn switch 15 Ω
DN/DP PIN SECTION
VDP_APP DP Apple mode output voltage — 2.52 2.8 3.08 V VDN_APP DN Apple mode output voltage — 2.52 2.8 3.08 V DP_DWM20K DP 20K pull down resistor — 18 20 22 kΩ DN_DWM20K DN 20K pull down resistor — 18 20 22 kΩ DP_DWM900K DP 900K pull down resistor — 600 — 1400 kΩ DN_DWM900K DN 900K pull down resistor — 600 — 1400 kΩ RDPDN_short DPDN short resistor — 5 20 40 Ω RDN_IMP Impedance check of DN for attach function — 100 — 350 Ω
DIGITAL I/O PIN SECTION
(DP/DN/GPIO1~GPIO8) VOH Logic Output High Level Voltage Source Current 4mA VCC-0.2 — — V VOL Logic Output Low Level Voltage Sink Current 4mA — — 200 mV IS_OTP Source Current for OTP Pins (GPIO3 and GPIO4) — 126 140 154 μA
ADC SECTION
VADC_REF ADC Reference Voltage — — 2.046 — V VOFFSET ADC Offset Voltage — — ±4.0 — mV
PROTECTION SECTION
VDP_OVP VABCVDP_OVP VDP_OVP 4.1 4.35 4.6 V VDN_OVP VDN_OVP VDN_OVP 4.1 4.35 4.6 V IVCONN_OCP VCONN Overcurrent Protection — 32 48 56 mA AP43776Q 10 of 13 November 2022 Document number: DS43207 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated
