Datasheet MAX9075, MAX9077 (Maxim) - 7
ManufacturerMaxim
DescriptionLow-Cost, Ultra-Small, 3µA Single-Supply Comparators
Pages / Page9 / 7 — MAX9075/MAX9077. Low-Cost, Ultra-Small, 3µA. Single-Supply Comparators. …
File Format / SizePDF / 141 Kb
MAX9075/MAX9077. Low-Cost, Ultra-Small, 3µA. Single-Supply Comparators. Pin Configurations (continued)
MAX9075/MAX9077 Low-Cost, Ultra-Small, 3µA Single-Supply Comparators Pin Configurations (continued)
4) Choose the threshold voltage for VIN rising (VTHR). In this example, choose VTHR = 3V. VCC 5) Calculate R2 as follows: R3 R2 = 1/{[VTHR/(VREF R1)] - 1/R1 - 1/R3} = R1 1/{[3 / (1.2 100kΩ)] - 1/100kΩ - 1/10MΩ} = 67.114kΩ VIN A 1% preferred value is 64.9kΩ. VCC OUT R2 6) Verify the threshold voltages with these formulas: GND V MAX9075 IN rising: VREF MAX9077 VTHR = VREF R1 (1/R1 + 1/R2 + 1/R3) VIN falling: VTHF = VTHR - (R1 VCC)/R3 Figure 1. Adding Hysteresis 7) Check the error due to input bias current (5nA). If the error is too large, reduce R3 and recalculate.
VTH = IB (R1 R2 R3)/(R1 + R2 + R3) = 0.2mV
Board Layout and Bypassing
TOP VIEW Use 10nF power-supply bypass capacitors. Use 100nF bypass capacitors when supply impedance is high, when supply leads are long, or when excessive noise is
expected on the supply lines. Minimize signal trace OUTA 1 8 VCC lengths to reduce stray capacitance. Minimize the GND 2 MAX9077 7 OUTB capacitive coupling between IN- and OUT. For slow- moving input signals (rise time > 1ms) use a 1nF INA- 3 6 INB- capacitor between IN+ and IN-. INA+ 4 5 INB+
Chip Information
PROCESS: BiCMOS
SOT23-8 +
OUTA 1 8 VCC INA- 2 7 OUTB MAX9077 INA+ 3 6 INB- GND 4 5 INB+ µ
MAX/SO
Maxim Integrated 7
