Datasheet MAX8863, MAX8864 (Analog Devices) - 3
DescriptionLow-Dropout, 120mA Linear Regulators
Pages / Page10 / 3 — Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. …
Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. SET INPUT. THERMAL PROTECTION. Note 2:. Note 3:
Electrical Characteristics (continued) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS SET INPUT THERMAL PROTECTION Note 2: Note 3:
MAX8863T/S/R, Low-Dropout, 120mA Linear Regulators MAX8864T/S/R
(VIN = +3.6V, VGND = 0V, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 2)
T SHDN Input Bias Current I A = +25°C 0 100 SHDN VSHDN = VIN nA TA = TMAX 0.05 T Shutdown Supply Current I A = +25°C 0.0001 1 QSHDN VOUT = 0V µA TA = TMAX 0.02 Shutdown Discharge Resistance (MAX8864) 300 Ω
SET INPUT
TA = +25°C 1.225 1.25 1.275 Set Reference Voltage VIN = 2.5V to 6.5V, (Note 4) VSET I E temp range 1.215 1.25 1.285 V OUT = 1mA M temp range 1.205 1.25 1.285 Set Input Leakage Current TA = +25°C 0.015 2.5 (Note 4) ISET VSET = 1.3V nA TA = TMAX 0.5
THERMAL PROTECTION
Thermal Shutdown Temperature TSHDN 170 °C Thermal Shutdown Hysteresis ∆TSHDN 20 °C
Note 2:
Limits are 100% production tested at TA = +25°C. Limits over the operating temperature range are guaranteed through cor- relation using Statistical Quality Control (SQC) Methods.
Note 3:
Guaranteed by line regulation test.
Note 4:
Adjustable mode only.
Note 5:
Not tested. For design purposes, the current limit should be considered 120mA minimum to 420mA maximum.
Note 6:
The dropout voltage is defined as (VIN - VOUT) when VOUT is 100mV below the value of VOUT for VIN = VOUT +2V.
Typical Operating Characteristics
(VIN = +3.6V, CIN = 1μF, COUT = 1μF, TA = +25°C, MAX886_T, unless otherwise noted.)
OUTPUT VOLTAGE SUPPLY CURRENT OUTPUT VOLTAGE vs. LOAD CURRENT vs. LOAD CURRENT vs. INPUT VOLTAGE
3.30 100 3.5 95 MAX8863/4-01 MAX8863/4-02 3.0 MAX8863/4-03 3.25 90 85 2.5 3.20 80 2.0 3.15 75 NO LOAD 70 1.5 3.10 OUTPUT VOLTAGE (V) SUPPLY CURRENT (µA) 65 OUTPUT VOLTAGE (V) 1.0 60 3.05 0.5 55 3.00 50 0 0 10 20 30 40 50 60 70 80 90 100 0 10 20 30 40 50 60 70 80 90 100 0 1 2 3 4 5 6 LOAD CURRENT (mA) LOAD CURRENT (mA) INPUT VOLTAGE (V) www.maximintegrated.com Maxim Integrated │ 3
