Datasheet NC100, NC200, NC300, NC400 (Noisecom) - 2
Manufacturer | Noisecom |
Description | Noise Diode |
Pages / Page | 4 / 2 — Noise Diodes. Audio & VHF Types. Model. Frequency. Operating … |
File Format / Size | PDF / 949 Kb |
Noise Diodes. Audio & VHF Types. Model. Frequency. Operating Conditions. Minimum Output. Package. Range. V (V). RL (Ω). (μV/ √Hz)
Noise Diodes
Noisecom’s noise diodes are the fundamental building blocks of The NC100 and NC200 Series diodes are designed for audio all noise systems. They are hand-picked for performance char- and RF applications. The NC300 and NC400 Series diodes are acteristics that make them ideally suited to broadband noise designed for microwave applications in which a 50-ohm imped- generation with flat response. ance is required. All Noisecom noise diodes deliver symmetrical white Gaussian Typical small signal impedance of the NC300 and NC400 Series noise and flat output power versus frequency. The diodes are is 10-20 ohms after a diode is biased. The output level is higher hermetically sealed and available in a wide variety of package at low frequencies with low currents and driving the diodes with styles. Special package configurations or screening processes higher current results in greater output at higher frequencies. are available upon request.
Audio & VHF Types Model Frequency Operating Conditions Minimum Output Package Range V (V) I RL (Ω) (μV/ √Hz) b op
NC101 0.1 Hz - 100 kHz 7 - 10 30 - 60 μA 2200 3.0 DO-35 NC102 0.1 Hz - 500 kHz 7 - 10 30 - 60 μA 2200 3.0 DO-35 NC103 0.1 Hz - 1 MHz 7 - 10 30 - 60 μA 2200 3.0 DO-35 NC104 0.1 Hz - 3 MHz 7 - 10 30 - 60 μA 2200 3.0 DO-35 NC201 0.1 Hz - 10 MHz 7 - 10 0.2 - 0.5 mA 2200 0.1 DO-35 NC202 0.1 Hz - 25 MHz 7 - 10 0.2 - 0.5 mA 2200 0.1 DO-35 NC203 0.1 Hz - 100 MHz 7 - 10 0.2 - 0.5 mA 50 0.05 DO-35
RF & Microwave Types Model Frequency Operating Conditions Output Package Range V (V) I (mA) RL (Ω) ENR (dB) b op
NC302L 10 Hz - 3 GHz 6 - 8 6 50 30 - 35 BL, CH1 NC302 10 Hz - 3 GHz 8 - 12 8 50 30 - 35 BL, CH1 NC303 10 Hz - 8 GHz 8 - 12 8 50 30 - 35 BL, CH1 NC303SQ 10 Hz - 10 GHz 8 - 12 8 50 30 - 35 SQ NC303R 10 Hz - 10 GHz 8 - 10 8 50 30 - 35 R NC305 10 MHz - 11 GHz 8 - 12 10 50 29 - 34 BL, CH1 NC401 100 MHz - 18 GHz 8 - 12 10 50 30 - 35 C10, C50H, CH2 NC403 100 MHz - 27 GHz 8 - 12 12 50 24 - 28 C50, CH3 NC404 18 GHz - 50 GHz 8 - 12 15 50 20 - 25 C50, CH3 NC405 18 GHz - 75 GHz 8 - 12 20 50 15 - 25 C50, CH3 NC407 1 GHz - 110 GHz 8 - 12 8 50 15 - 25 B 1. For chip configuration, add suffix “C”. 2. For beam lead configuration, add suffix “BL”. 3. For C50H configuration, add suffix “H”. 4. ESD Rating for NC401C is 1C. 2
