Datasheet NC100, NC200, NC300, NC400 (Noisecom) - 3
ManufacturerNoisecom
DescriptionNoise Diode
Pages / Page4 / 3 — Specifications. Typical Bias Circuit. CH1 Chip (inches). CH2 Chip …
File Format / SizePDF / 949 Kb
Specifications. Typical Bias Circuit. CH1 Chip (inches). CH2 Chip (inches). CH3 Chip (inches). C10 (inches). C50 (inches)
Specifications Typical Bias Circuit CH1 Chip (inches) CH2 Chip (inches) CH3 Chip (inches) C10 (inches) C50 (inches)
For NC100 Series CATHODE R = 150K R For NC200 Series Output White Gaussian Noise C + R = 15K Operating temperature -40°C to +85°C temperature for V 5 1 F R RL For NC300/400 Series DO-35 package R = Adjust for performance – -55°C to +125°C for all others R L= Load resistor For recommended value, Storage temperature -65°C to +150°C C ≥ 1 2πRL(fc) see charts on reverse page fc= low frequency cut-off
CH1 Chip (inches) CH2 Chip (inches) CH3 Chip (inches) C10 (inches) C50 (inches) C50H (inches) DO-35 Package (inches) BL Package (inches)
2 1 APPLICATION REVISION HISTORY NEXT ASSY USED ON REV ECO DESCRIPTION BY DATE APPVD 2 1 APPLICATION REVISION HISTORY NEXT ASSY USED ON REV ECO DESCRIPTION BY DATE APPVD
B Package (inches) SQ Package (inches)
.008 .010 B B B B .070 .035 0 CATHODE 5 0 0 1 0. 0. 210. 07 8 0 4 . 0. GLASS .008 300 .029 0. CATHODE DOT .015 .033 SQ Package (inches) N+ SILICON B Package (inches) NOISE/COM PROPRIETARY RIGHTS ARE INCLUDED IN THIS INFORMATION DISCLOSED HEREIN. NEITHER THIS A DOCUMENT NOR THE INFORMATION DISCLOSED HEREIN SHALL BE REPRODUCED OR TRANSFERRED TO OTHER A DOCUMENTS OR USED OR DISCLOSED TO OTHERS FOR MANUFACTURING OR ANY OTHER PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY NOISE/COM. NOISE/COM PROPRIETARY RIGHTS ARE INCLUDED IN THIS DOES NOT APPLY TO INFORMATION FURNISHED BY THIS INFORMATION DISCLOSED HEREIN. NEITHER THIS VENDOR OR OTHERS OUTSIDE NOISE/COM. A DOCUMENT NOR THE INFORMATION DISCLOSED HEREIN SHALL BE REPRODUCED OR TRANSFERRED TO OTHER A UNLESS OTHERWISE SPECIFIED DOCUMENTS OR USED OR DISCLOSED TO OTHERS FOR 3 DIMENSIONS ARE IN INCHES CONTRACT NO. MANUFACTURING OR ANY OTHER PURPOSE EXCEPT TOLERANCES ARE: AS SPECIFICALLY AUTHORIZED IN WRITING BY NOISE/COM. THIS DOES NOT APPLY TO INFORMATION FURNISHED BY FRACTIONS DECIMALS ANGLES A WIRELESS TELECOM GROUP COMPANY VENDOR OR OTHERS OUTSIDE NOISE/COM. +/- 1/64 .XX +/- .010 +/- 30' .XXX +/- .005 APPROVALS DATE UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN INCHES CONTRACT NO. MATERIAL: DRAWN TOLERANCES ARE: M.WHEELER 4/21/2014 FRACTIONS DECIMALS ANGLES A WIRELESS TELECOM GROUP COMPANY CHECKED +/- 1/64 .XX +/- .010 +/- 30' FINISH: SIZE CAGE CODE DWG NO REV .XXX +/- .005 APPROVALS DATE DES. ENG. MATERIAL: DRAWN A 65185 DIODE_MPULS E_B1_101B-1 M.WHEELER 4/21/2014 ENG. DO NOT SCALE DRAWING SCALE: SHEET 1 OF 1 CHECKED FINISH: 2 1 SIZE CAGE CODE DWG NO REV DES. ENG. A 65185 DIODE_303SQ _BL ENG. DO NOT SCALE DRAWING SCALE: SHEET 1 OF 1 2 1
