Datasheet MBT3906DW1 (ON Semiconductor) - 7
Manufacturer | ON Semiconductor |
Description | Dual General Purpose Transistor |
Pages / Page | 9 / 7 — PACKAGE DIMENSIONS. SC−88/SC70−6/SOT−363. SCALE 2:1. GAGE. PLANE. DETAIL … |
File Format / Size | PDF / 354 Kb |
PACKAGE DIMENSIONS. SC−88/SC70−6/SOT−363. SCALE 2:1. GAGE. PLANE. DETAIL A. 2X 3 TIPS. MILLIMETERS. INCHES. DIM MIN. NOM. MAX. MIN. 6X b. TOP VIEW
MECHANICAL CASE OUTLINE
PACKAGE DIMENSIONS SC−88/SC70−6/SOT−363
CASE 419B−02 ISSUE Y 1 DATE 11 DEC 2012
SCALE 2:1 2X
aaa H D NOTES:
D H
1. DIMENSIONING AND TOLERANCING PER ASME Y14.5M, 1994. 2. CONTROLLING DIMENSION: MILLIMETERS.
A
3. DIMENSIONS D AND E1 DO NOT INCLUDE MOLD FLASH,
D
PROTRUSIONS, OR GATE BURRS. MOLD FLASH, PROTRU-
GAGE
SIONS, OR GATE BURRS SHALL NOT EXCEED 0.20 PER END.
PLANE
4. DIMENSIONS D AND E1 AT THE OUTERMOST EXTREMES OF THE PLASTIC BODY AND DATUM H.
6 5 4
5. DATUMS A AND B ARE DETERMINED AT DATUM H.
L2 L
6. DIMENSIONS b AND c APPLY TO THE FLAT SECTION OF THE
E E1
LEAD BETWEEN 0.08 AND 0.15 FROM THE TIP.
DETAIL A
7. DIMENSION b DOES NOT INCLUDE DAMBAR PROTRUSION.
1 2 3
ALLOWABLE DAMBAR PROTRUSION SHALL BE 0.08 TOTAL IN EXCESS OF DIMENSION b AT MAXIMUM MATERIAL CONDI- aaa C
2X
TION. THE DAMBAR CANNOT BE LOCATED ON THE LOWER
2X 3 TIPS
RADIUS OF THE FOOT. bbb H D
e MILLIMETERS INCHES DIM MIN NOM MAX MIN NOM MAX B 6X b A
−−− −−− 1.10 −−− −−− 0.043 ddd M C
A1
0.00 −−− 0.10 0.000 −−− 0.004
TOP VIEW
A-B D
A2
0.70 0.90 1.00 0.027 0.035 0.039
b
0.15 0.20 0.25 0.006 0.008 0.010
C
0.08 0.15 0.22 0.003 0.006 0.009
A2 D
1.80 2.00 2.20 0.070 0.078 0.086
DETAIL A A E
2.00 2.10 2.20 0.078 0.082 0.086
E1
1.15 1.25 1.35 0.045 0.049 0.053
e
0.65 BSC 0.026 BSC
L
0.26 0.36 0.46 0.010 0.014 0.018
L2
0.15 BSC 0.006 BSC
aaa
0.15 0.006
bbb
0.30 0.012
ccc
0.10 0.004
6X
ccc C
A1 SEATING C c ddd
0.10 0.004
SIDE VIEW PLANE END VIEW GENERIC MARKING DIAGRAM* RECOMMENDED
6
SOLDERING FOOTPRINT*
6X 6X XXXMG 0.30 0.66 G 1 2.50 XXX = Specific Device Code M = Date Code* G = Pb−Free Package 0.65 (Note: Microdot may be in either location) PITCH DIMENSIONS: MILLIMETERS *Date Code orientation and/or position may vary depending upon manufacturing location. *For additional information on our Pb−Free strategy and soldering details, please download the ON Semiconductor Soldering and *This information is generic. Please refer to Mounting Techniques Reference Manual, SOLDERRM/D. device data sheet for actual part marking. Pb−Free indicator, “G” or microdot “G”, may or may not be present. Some products may not follow the Generic Marking.
STYLES ON PAGE 2 DOCUMENT NUMBER: 98ASB42985B
Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red.
DESCRIPTION: SC−88/SC70−6/SOT−363 PAGE 1 OF 2 onsemi
and are trademarks of Semiconductor Components Industries, LLC dba
onsemi
or its subsidiaries in the United States and/or other countries.
onsemi
reserves the right to make changes without further notice to any products herein.
onsemi
makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does
onsemi
assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages.
onsemi
does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 2019 www.onsemi.com
