Datasheet AP7179D (Diodes) - 6
Manufacturer | Diodes |
Description | 3A, Ultra Low Noise, High Accuracy, LDO Voltage Regulator |
Pages / Page | 20 / 6 — AP7179D. Absolute Maximum Ratings. Symbol. Parameter. Ratings. Unit. … |
File Format / Size | PDF / 2.8 Mb |
AP7179D. Absolute Maximum Ratings. Symbol. Parameter. Ratings. Unit. Recommended Operating Conditions. Min. Max
AP7179D Absolute Maximum Ratings
(Note 4) (@TA = +25°C, unless otherwise specified.)
Symbol Parameter Ratings Unit
ESD HBM Human Body Mode ESD Protection 2 kV CDM Charged Device Model 500 V VIN Input Voltage -0.3 to 7 V VEN Input Voltage for EN Pin -0.3 to 7 V VPG Power Good Indictor Voltage -0.3 to 7 V VOUT Output Voltage -0.3 to VIN + 0.3 V VNR/SS VNR/SS Pin Voltage -0.3 to 2 V VFB Feedback Pin Voltage -0.3 to 2 V TJ Operating Junction Temperature 150 °C TSTG Storage Temperature -55 to +150 °C θJA Thermal Resistance Junction to Ambient (JA) 65.4 °C/W Notes: 4. a). Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these conditions is not implied. Exposure to absolute-maximum-rated conditions for extended period may affect device reliability. b). Ratings apply to ambient temperature at +25°C. The JEDEC High-K board design used to derive this data was a 3 inch x 3 inch multilayer board with 1oz. internal power and ground planes and 2oz. copper traces on the top and bottom of the board.
Symbol Parameter Min Max Unit
VIN Input Voltage 1.1 6.5 V IOUT Each Channel Output Current 0 3 A TJ Operating Junction Temperature -40 +125 °C
Electrical Characteristics
Over operating temperature range (TJ = −40°C to 125°C), (1.1V ≤ VIN < 6.5V and VIN ≥ VOUT(TARGET) + 0.3 V, VOUT(TARGET) = 0.8V, VOUT connected to 50Ω to GND, VEN = 1.1 V, CIN = 10μF, COUT = 47μF, CNR/SS = 0nF, CFF = 0nF, and PG pin pulled up to VIN with 100 kΩ, unless otherwise noted. (Note 5)
Parameter Symbol Test Conditions Min Typ Max Unit
Input Voltage Range VIN 1.1 -- 6.5 V Feedback Reference Voltage VFB -- 0.8 -- V NR/SS Pin Voltage VNR/SS -- 0.8 --- V VUVLO VIN increasing -- 1.02 1.085 V Undervoltage Lock-Out VHYS Hysteresis -- 150 -- mV Using voltage setting pins (50mV, 100mV, 0.8 -1% -- 3.95+ 1% V 200mV, 400mV, 800mV, and 1.6V) Output Voltage Range Using external resistors 0.8 - 1% -- 5 + 1% V Output Voltage Accuracy VIN = VOUT + 0.3V, 0.8V ≤ VOUT ≤ 5V, V -1 -- 1 % (Note 6) OUT 5mA ≤ IOUT ≤ 3A ∆VOUT/ Line Regulation I ∆ OUT = 5mA, 1.4V ≤ VIN ≤ 6.5 V -- 0.05 -- %/V VIN ∆VOUT/ Load Regulation 5mA ≤ I ∆ OUT ≤ 3A -- 0.08 -- %/A IOUT Dropout Voltage VDROP VIN = 1.1V to 6.5V, IOUT = 3A, VFB = 0.8V - 3% -- 110 180 mV V Output Current Limit I OUT = 90% VOUT(TARGET), VIN = VOUT(TARGET) + LIM 3.7 4.2 4.7 A 0.4V AP7179D 6 of 20 January 2023 Document number: DS42129 Rev. 2 - 2
www.diodes.com
© 2023 Copyright Diodes Incorporated. All Rights Reserved.
