Datasheet 4PID-10, 4PID-50, 4PID-100, 4PID-200, 4PID-2000, 4PID-5000, 4PID-10000 (Senovol)
ManufacturerSenovol
DescriptionPhotoionization Detector (PID) Sensors
Pages / Page2 / 1 — Photoionization. Detector. (PID). Sensors. 4-Series. Senovol. PID. …
File Format / SizePDF / 600 Kb
Photoionization. Detector. (PID). Sensors. 4-Series. Senovol. PID. sensors. are. designed. for. the. detection. of. a. wide. variety. of. volatile. organic
Datasheet 4PID-10, 4PID-50, 4PID-100, 4PID-200, 4PID-2000, 4PID-5000, 4PID-10000 Senovol
Photoionization Detector (PID) Sensors 4-Series Senovol PID sensors are designed for the detection of a wide variety of volatile organic compounds (VOCs). In general, any compound with an ionization energy (IE) lower than that of the lamp photons can be measured. Based on its proprietary ultraviolet (UV) lamp technology, Senovol PID sensors have the advanced features of high UV outputs, and long lamp life spans. Product Dimensions Top View Side View Bottom View All dimensions in mm Performance Environmental Photon energy 10.6 eV Temperature range -20ºC ~ +50ºC Measurement range 0 ~ 10,000 ppm isobutylene Pressure range 1 atm ± 10% Resolution 5 ~ 2,000 ppb isobutylene Humidity range 15 % ~ 95 %RH Response time (T90) < 5 seconds Non-condensing Baseline shift (20oC) 70 ± 15 mV Linearity linear from 0.045 ~ 2.5 V Life Time Storage Temp 0 ℃ ~ 30 ℃ Electrical Operating lifetime 5 years (excluding lamp and Supply voltage 3.2 ~ 5.5 V electrodes) Working current < 35 mA at 5 V Typical lamp life 10,000 hours Output signal 0.045 ~ 2.5 V Storage life 2 years in original packaging Warranty 12 months Mechanical Enclosure Stainless steel Approvals Weight 15 grams CE Pending Intrinsic safety certification Installation The output signals from the sensor pins are different. Inappropriate use of the pins in product design wil affect the sensor functionality. Exposure to high concentrations of solvent vapors should be avoided under any condition. Mechanical overstress may cause deformation of the sensor enclosure and damage the internal components including the lamp. If the sensor is used in extreme environmental conditions, please contact us for more details. info@senovol.com www.senovol.com
