Datasheet KA-3528SURCKT (Kingbright)
Manufacturer | Kingbright |
Description | 3.5 x 2.8 mm Surface Mount LED Lamp |
Pages / Page | 4 / 1 — KA-3528SURCKT. DESCRIPTIONS. PACKAGE DIMENSIONS. FEATURES. APPLICATIONS. … |
File Format / Size | PDF / 868 Kb |
KA-3528SURCKT. DESCRIPTIONS. PACKAGE DIMENSIONS. FEATURES. APPLICATIONS. RECOMMENDED SOLDERING PATTERN. Kingbright. ATTENTION
KA-3528SURCKT
DESCRIPTIONS PACKAGE DIMENSIONS
The Hyper Red source color devices are made with AlGaInP on GaAs substrate Light Emitting Diode Electrostatic discharge and power surge could damage the LEDs It is recommended to use a wrist band or anti-electrostatic glove when handling the LEDs All devices, equipments and machineries must be electrically grounded
FEATURES
Single color Suitable for all SMD assembly and solder process Available on tape and reel Ideal for backlighting Package: 2000 pcs / reel Moisture sensitivity level: 3 Halogen-free RoHS compliant
Backlight
(units : mm; tolerance : ± 0.1) Status indicator Home and smart appliances
Kingbright
Wearable and portable devices Healthcare applications
ATTENTION
Observe precautions for handling electrostatic discharge sensitive devices Notes: 1. All dimensions are in millimeters (inches). 2. Tolerance is ±0.25(0.01") unless otherwise noted. 3. The specifications, characteristics and technical data described in the datasheet are subject to change without prior notice. 4. The device has a single mounting surface. The device must be mounted according to the specifications.
SELECTION GUIDE Iv (mcd) @ 20mA
[2]
Viewin g Angle
[1]
Emitting Color Part Number Lens Type (Material) Min. Typ. 2θ1/2
150 350 KA-3528SURCKT ■ Hyper Red (AlGaInP) Water Clear 120° *55 *100 Notes: 1. θ1/2 is the angle from optical centerline where the luminous intensity is 1/2 of the optical peak value. 2. Luminous intensity / luminous flux: +/-15%. * Luminous intensity value is traceable to CIE127-2007 standards. © 2021 Kingbright. All Rights Reserved. Spec No: DSAI6720 / 1201004210 Rev No: V.14A Date: 09/17/2021 Page 1 / 4
