Datasheet KA-3528SURCKT (Kingbright) - 3
Manufacturer | Kingbright |
Description | 3.5 x 2.8 mm Surface Mount LED Lamp |
Pages / Page | 4 / 3 — KA-3528SURCKT. TECHNICAL DATA. RELATIVE INTENSITY vs. WAVELENGTH. SPATIAL … |
File Format / Size | PDF / 868 Kb |
KA-3528SURCKT. TECHNICAL DATA. RELATIVE INTENSITY vs. WAVELENGTH. SPATIAL DISTRIBUTION. HYPER RED. Forward Current vs
KA-3528SURCKT TECHNICAL DATA RELATIVE INTENSITY vs. WAVELENGTH SPATIAL DISTRIBUTION
Red 100% 0° -15° 15° T .) a = 25 °C Ta = 25 °C -30° 30° 80% . u (a ity -45° 45° s 60% n te In 40% 60° e -60° tiv la e 20% R -75° 75° 0% 350 400 450 500 550 600 650 700 750 800 -90° 90° Wavelength (nm) 1.0 0.5 0.0 0.5 1.0
HYPER RED Forward Current vs. Luminous Intensity vs. Forward Current Derating Curve Luminous Intensity vs. Forward Voltage Forward Current Ambient Temperature
50 2.5 50 2.5 d d T t a = 25 °C e T e a = 25 °C n ) 40 lis lis a 2.0 rre 40 a 2.0 A u rm c rm t (m o o n rd °C 30 n A 1.5 a 30 ) n 5 1.5 rre ity m rw A ity 2 u s 0 s n n = c fo (m a 20 te t 2 te rd 1.0 a le 20 1.0 a in ib t T s in a rw s s o u is u 10 o o F 0.5 in 10 rm 0.5 in m e m u P u 0 L 0.0 0 L 0.0 1.5 1.7 1.9 2.1 2.3 2.5 0 10 20 30 40 50 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 Forward voltage (V) Forward current (mA) Ambient temperature (°C) Ambient temperature (°C)
Kingbright REFLOW SOLDERING PROFILE for LEAD-FREE SMD PROCESS TAPE SPECIFICATIONS
(units : mm)
REEL DIMENSION
(units : mm) Notes: 1. Don't cause stress to the LEDs while it is exposed to high temperature. 2. The maximum number of reflow soldering passes is 2 times. 3. Reflow soldering is recommended. Other soldering methods are not recommended as they might cause damage to the product. © 2021 Kingbright. All Rights Reserved. Spec No: DSAI6720 / 1201004210 Rev No: V.14A Date: 09/17/2021 Page 3 / 4
