Datasheet MC10EP16, MC100EP16 (ON Semiconductor) - 4
ManufacturerON Semiconductor
Description3.3 V/5 V ECL Differential Receiver/Driver
Pages / Page13 / 4 — MC10EP16, MC100EP16. Table 5. 10EP DC CHARACTERISTICS, PECL. −40. Symbol. …
File Format / SizePDF / 357 Kb
MC10EP16, MC100EP16. Table 5. 10EP DC CHARACTERISTICS, PECL. −40. Symbol. Characteristic. Min. Typ. Max. Unit
MC10EP16, MC100EP16 Table 5 10EP DC CHARACTERISTICS, PECL −40 Symbol Characteristic Min Typ Max Unit
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
MC10EP16, MC100EP16 Table 5. 10EP DC CHARACTERISTICS, PECL
(VCC = 5.0 V, VEE = 0 V (Note 1))
−40
C 25
C 85
C Symbol Characteristic Min Typ Max Min Typ Max Min Typ Max Unit
IEE Power Supply Current 20 24 31 20 24 31 20 24 32 mA VOH Output HIGH Voltage (Note 2) 3865 3990 4115 3930 4055 4180 3990 4115 4240 mV VOL Output LOW Voltage (Note 2) 3065 3190 3315 3130 3255 3380 3190 3315 3440 mV VIH Input HIGH Voltage (Single-Ended) 3790 4115 3855 4180 3915 4240 mV VIL Input LOW Voltage (Single-Ended) 3065 3390 3130 3455 3190 3515 mV VBB Output Voltage Reference 3490 3590 3690 3555 3655 3755 3615 3715 3815 mV VIHCMR Input HIGH Voltage Common Mode 2.0 5.0 2.0 5.0 2.0 5.0 V Range (Differential Configuration) (Note 3) IIH Input HIGH Current 150 150 150 mA IIL Input LOW Current mA D 0.5 0.5 0.5 D −150 −150 −150 NOTE: Device will meet the specifications after thermal equilibrium has been established when mounted in a test socket or printed circuit board with maintained transverse airflow greater than 500 lfpm. 1. Input and output parameters vary 1:1 with VCC. VEE can vary +2.0 V to −0.5 V. 2. All loading with 50 W to VCC − 2.0 V. 3. VIHCMR min varies 1:1 with VEE, VIHCMR max varies 1:1 with VCC. The VIHCMR range is referenced to the most positive side of the differential input signal.
Table 6. 10EP DC CHARACTERISTICS, NECL
(VCC = 0 V; VEE = −5.5 V to −3.0 V (Note 1))
−40
C 25
C 85
IEE Power Supply Current 20 24 31 20 24 31 20 24 32 mA VOH Output HIGH Voltage (Note 2) −1135 −1010 −885 −1070 −945 −820 −1010 −885 −760 mV VOL Output LOW Voltage (Note 2) −1935 −1810 −1685 −1870 −1745 −1620 −1810 −1685 −1560 mV VIH Input HIGH Voltage (Single-Ended) −1210 −885 −1145 −820 −1085 −760 mV VIL Input LOW Voltage (Single-Ended) −1935 −1610 −1870 −1545 −1810 −1485 mV VBB Output Voltage Reference −1510 −1410 −1310 −1445 −1345 −1245 −1385 −1285 −1185 mV VIHCMR Input HIGH Voltage Common Mode VEE + 2.0 0.0 VEE + 2.0 0.0 VEE + 2.0 0.0 V Range (Differential Configuration) (Note 3) IIH Input HIGH Current 150 150 150 mA IIL Input LOW Current mA D 0.5 0.5 0.5 D −150 −150 −150 NOTE: Device will meet the specifications after thermal equilibrium has been established when mounted in a test socket or printed circuit board with maintained transverse airflow greater than 500 lfpm. 1. Input and output parameters vary 1:1 with VCC. 2. All loading with 50 W to VCC − 2.0 V. 3. VIHCMR min varies 1:1 with VEE, VIHCMR max varies 1:1 with VCC. The VIHCMR range is referenced to the most positive side of the differential input signal.
www.onsemi.com 4
