Datasheet SiC967 (Vishay) - 5
ManufacturerVishay
Description4.5 V to 60 V Input, 6 A, MicroBRICK DC/DC Regulator Module
Pages / Page22 / 5 — SiC967. ELECTRICAL SPECIFICATIONS. PARAMETER. SYMBOL. TEST CONDITIONS. …
File Format / SizePDF / 847 Kb
SiC967. ELECTRICAL SPECIFICATIONS. PARAMETER. SYMBOL. TEST CONDITIONS. MIN. TYP. MAX. UNIT. Fault Protections. Power Good
SiC967 ELECTRICAL SPECIFICATIONS PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNIT Fault Protections Power Good
SiC967
(VIN = VCIN = 48 V, TJ = -40 °C to +125 °C, unless otherwise stated)
PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT Fault Protections
ILM tied to VDD - 10 - Valley current limit IOCP ILM is not connect - 7.5 - A ILM tied to AGND - 5 - Output OVP threshold OVP - 20 - VFB with respect to 0.8 V reference % Output UVP threshold UVP - -80 - OTPR Rising temperature - 150 - Over temperature protection °C OTPHYST Hysteresis - 35 -
Power Good
VFB_RISING_VTH_OV VFB rising above 0.8 V reference - 20 - Power good output threshold % VFB_FALLING_VTH_U VFB falling below 0.8 V reference - -10 - V Power good hysteresis PGOOD_HYST 40 60 80 mV Power good on resistance RON_PGOOD - 15 25 Power good delay time tDLY_PGOOD 15 25 35 μs
EN / MODE / Ultrasonic Threshold
EN logic high level VEN_H 1.2 1.4 1.5 V EN logic low level VEN_L 1.00 1.12 1.25 EN logic hysteresis VEN_HYS 200 280 360 mV EN pull down resistance REN - 5 - M Ultrasonic mode high Level UHIGH 2 - - V Ultrasonic mode low level ULOW - - 0.8 Mode pull up current IMODE - 5 - μA Power save mode enabled, V Mode 1 DD, - 2 - VDRV pre-reg on Power save mode disabled, V Mode 2 DD, - 301 - VDRV pre-reg on R Power save mode disabled, MODE k Mode 3 VDRV pre-reg off, VDD pre-reg on, - 499 - provide external VDRV Power save mode enabled, Mode 4 VDRV pre-reg off, VDD pre-reg on, - 1000 - provide external VDRV
Soft Start
Soft start timing (1) - 6 - ms
Note
(1) Guaranteed by design S23-0680-Rev. C, 28-Aug-2023
5
Document Number: 76444 For technical questions, contact: powerictechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
