Datasheet MAX4240, MAX4241, MAX4242, MAX4243, MAX4244 (Analog Devices) - 3
DescriptionSingle/Dual/Quad, +1.8V/10µA, SOT23, Beyond-the-Rails Op Amps
Pages / Page16 / 3 — Single/Dual/Quad, +1.8V/10µA, SOT23,. Beyond-the-Rails Op Amps. …
Single/Dual/Quad, +1.8V/10µA, SOT23,. Beyond-the-Rails Op Amps. MAX4240–MAX424. ELECTRICAL CHARACTERISTICS (continued)
Single/Dual/Quad, +1.8V/10µA, SOT23, Beyond-the-Rails Op Amps MAX4240–MAX424 ELECTRICAL CHARACTERISTICS (continued)
(VCC = +1.8V to +5.5V, VEE = 0, VCM = 0, VOUT = VCC / 2, RL = 100kΩ tied to VCC / 2, SHDN = VCC, TA = +25°C, unless otherwise noted.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX4241ESA 77 85 MAX4242ESA/MAX4243ESD/ Power-Supply 77 85 PSRR 1.8V ≤ VCC ≤ 5.5V MAX4244ESD dB Rejection Ratio MAX4240EUK/MAX424_EUA/ 75 82 MAX4243EUB R V L = 100kΩ 76 85 CC = 1.8V Large-Signal (V A EE + 0.2V) ≤ VOUT ≤ RL = 10kΩ 66 73 VOL dB Voltage Gain (VCC - 0.2V) R V L = 100kΩ 86 94 CC = 5.0V RL = 10kΩ 78 85 R V L = 100kΩ 8 20 CC = 1.8V Output Voltage Specified as R V L = 10kΩ 40 65 OH mV
4
Swing High ⎥ VCC - VOH⎥ R V L = 100kΩ 10 25 CC = 5.0V RL = 10kΩ 60 95 R V L = 100kΩ 6 15 CC = 1.8V Output Voltage Specified as R V L = 10kΩ 23 35 OL mV Swing Low ⎥ VEE - VOL⎥ R V L = 100kΩ 10 20 CC = 5.0V RL = 10kΩ 40 60 Output Short-Circuit Sourcing 0.7 IOUT(SC) mA Current Sinking 2.5 Output Leakage Current in Shutdown IOUT(SHDN) SHDN = VEE = 0, VCC = 5.5V 20 50 nA (Notes 2, 5) SHDN Logic Low V (Note 2) IL 0.3 x VCC V SHDN Logic High V (Note 2) IH 0.7 x VCC V SHDN Input Bias I Current (Note 2) IH, IIL SHDN = VCC = 5.5V or SHDN = VEE = 0 40 80 nA Channel-to-Channel CH Isolation (Note 6) ISO Specified at DC 80 dB Gain-Bandwidth GBW 90 kHz Product Phase Margin Φ m 68 degrees Gain Margin Gm 18 dB Slew Rate SR 40 V/ms
_______________________________________________________________________________________ 3
