Surface Mount PTC 0ZAF Series 0ZAF Series – 2920 Chip RoHS Compliant Product Features - 2920 Dimension, Surface mountable, Solid state, Faster time to trip than standard SMD devices. - Full compliance with EU Directive 2011/65/EU and amending directive 2015/863 - AEC-Q Compliant - Meets Bel automotive qualification* * - Largely based on internal AEC-Q test plan Operating (Hold Current) Range 50mA – 160mA Maximum Voltage 240VAC/250VAC (per table) Temperature Range -40°C to 85°C Agency Approval TUV (Std. EN/IEC 60738-1/60738-1-1 and EN/IEC 60730-1, Cert. R50102117) UL Recognized Component (Std. UL1434, File E305051) AEC-Q Compliant LEAD FREE = HALOGEN FREE = Electrical Characteristics (23) Max. Max Time to Trip Resistance Tolerance Agency Approvals Hold Trip Max. Max. Int. Typ. Oper. Current Current Current Voltage Power Part Number Voltage Current Time Rmin Rmax R1max IH, A IT, A Imax, A Vmax, Vac VI-max, Vac Pd, W A Sec Ohms Ohms Ohms A 0ZAF0005FF28 0.05 0.12 1.0 240 250 1.5 0.25 15.00 10.0 55.0 70.0 Y Y B 0ZAF0008FF28 0.08 0.19 1.2 240 250 1.5 0.40 15.00 6.0 16.0 25.0 Y Y C 0ZAF0012FF28 0.12 0.30 1.2 240 250 1.5 0.60 15.00 6.0 14.0 20.0 Y Y D 0ZAF0013FF28 0.13 0.32 1.2 240 250 1.5 0.65 15.00 2.0 6.0 12.0 Y Y E 0ZAF0016FF28 0.16 0.37 2.0 240 250 1.5 0.80 15.00 2.0 6.0 11.0 Y Y IH Hold Current- The maximum current at which the device will not trip in still air at 23° C. IT Trip current- The minimum current at which the device will trip in still air at 23° C. Vmax Maximum voltage device can withstand at its rated current without suffering damage. Imax Maximum fault current device can withstand at rated voltage (Vmax) without damage. Pd Typical power dissipated-type amount of power dissipated by device when in tripped state in 23° C still air environment. Rmin Minimum device resistance at 23℃ prior to tripping. Rmax Maximum device resistance at 23℃. R1max Maximum device resistance at 23℃ measured 1 hour after tripping or reflow soldering of 260℃ for 20 seconds. Specifications subject to change without notice belfuse.com/circuit-protection
