Datasheet 0ZAF (Bel) - 3
ManufacturerBel
DescriptionSurface Mount PTC
Pages / Page4 / 3 — Pad Layout Termination Pad Materials. Mechanical Dimensions and Marking. …
File Format / SizePDF / 569 Kb
Pad Layout Termination Pad Materials. Mechanical Dimensions and Marking. Temperature Derating Table. I Hold Value. -40. -20
Pad Layout Termination Pad Materials Mechanical Dimensions and Marking Temperature Derating Table I Hold Value -40 -20
Type 0ZAF Series
3
4 Pad Layout Termination Pad Materials
The dimensions in the table below provide the Pure Tin Recommended pad layout. P S W Nominal Nominal Nominal mm Inch mm Inch mm Inch 5.10 0.201 2.30 0.091 5.60 0.221
All dimensions in mm. Dimensions Marking Code Part Number C “b”, IH code Min Max 0005 0ZAF0005FF28 2.00 2.60 240 0008 0ZAF0008FF28 2.00 2.60 240 0012 0ZAF0012FF28 2.00 2.60 240 0013 0ZAF0013FF28 2.00 2.60 240 0016 0ZAF0016FF28 2.00 2.60 240
I Hold Value -40 -20 0 23 30 40 50 60 70 85
0ZAF 158% 140% 120% 100% 93% 82% 72% 63% 54% 40%
Thermal Derating Curve Cautionary Notes
1. Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. Temperature Rerating Curve 2. These Polymer PTC (PPTC) devices are intended for protection 180% against occasional overcurrent/overtemperature fault conditions 160% and may not be suitable for use in applications where repeated t n and/or prolonged fault conditions are anticipated. 140% er 3. Avoid contact of PTC device with chemical solvent. Prolonged 120% Cur contact may adversely impact the PTC performance. pi 100% r 4. These PTC devices may not be suitable for use in circuits with a T large inductance, as the PTC trip can generate circuit voltage d 80% n spikes above the PTC rated voltage. a 60% d 5. If potting is mandated, avoid rigid potting compounds as they will 40% Hol encase the PTC and prevent it from volumetrically expanding to f o properly respond to a trip event. 20% t n 6. MSL: 2a (According to IPC J-Std-020). e 0% cre -40 -20 0 20 40 60 80 P Temperature(° C) Specifications subject to change without notice
Bel Fuse Inc.
+1 201.432.0463 206 Van Vorst Street Bel.US.CS@belf.com Jersey City, NJ 07302 USA
belfuse.com/circuit-protection
© 2023 Bel Fuse, Inc. Rev. 0ZAF May2023
