2W005M THRU 2W10M Single Phase 2.0 AMPS. Silicon Bridge Rectifiers Voltage Range 50 to 1000 Volts Current 2.0 Amperes WOBFeatures UL Recognized File # E-96005 Surge overload ratings to 50 amperes peak Ideal for printed circuit board Reliable low cost construction technique results in inexpensive product High temperature soldering guaranteed: 260℃ / 10 seconds / 0.375” ( 9.5mm ) lead length at 5 lbs., ( 2.3 kg ) tension Mechanical Data Case: Molded plastic Lead: Solder plated Polarity: As marked Weight: 1.10 grams Dimensions in inches and (millimeters)Maximum Ratings and Electrical Characteristics Rating at 25℃ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20% Type NumberSymbol 2W2W2W2W2W2W2W Units 005M 01M 02M 04M 06M 08M 10M Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current I @T (AV) 2.0 A A = 50℃ Peak Forward Surge Current, 8.3 ms Single Half Sine-wave Superimposed on Rated IFSM 50 A Load (JEDEC method ) Maximum Instantaneous Forward Voltage V @ 2.0A F 1.1 V Maximum DC Reverse Current @ TA=25℃ 10 uA I at Rated DC Blocking Voltage @ T R A=100℃ 500 uA Typical Thermal Resistance (Note) RθJA 40 ℃ /W RθJL 15 Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTG -55 to +150 ℃ Note: Thermal Resistance from Junction to Ambient and from Junction to Lead at 0.375” (9.5mm) Lead Length for P.C.B. Mounting. - 666 - Document Outline 666.eps 667-2W005M THRU 2W10M.eps
