Datasheet 2W005M, 2W01M, 2W02M, 2W04M, 2W06M, 2W08M, 2W10M (Taiwan Semiconductor) - 2
ManufacturerTaiwan Semiconductor
DescriptionSingle Phase 2.0 AMPS Silicon Bridge Rectifiers
Pages / Page2 / 2 — - 667 -
File Format / SizePDF / 87 Kb
- 667 -
RATINGS AND CHARACTERISTIC CURVES (2W005M THRU 2W10M) FIG.1- MAXIMUM NON-REPETITIVE FORWARD FIG.2- MAXIMUM CURRENT DERATING CURVE SURGE CURRENT PER BRIDGE ELEMENT OUTPUT RECTIFIED CURRENT 50 2.0 (A) . 8.3ms Single Half Sine Wave (A) RESISTIVE JEDEC Method . 40 INDUCTIVE LOAD 1.5 CURRENT 30 CURRENT SURGE ARD 1.0 W ARD 20 W FOR FOR 0.5 10 VERAGE PEAK A 0 0 1 10 100 20 40 60 80 100 120 140 o NUMBER OF CYCLES AT 60Hz AMBIENT TEMPERATURE. ( C) FIG.3- TYPICAL INSTANTANEOUS FORWARD FIG.4- TYPICAL REVERSE CHARACTERISTICS CHARACTERISTICS PER BRIDGE ELEMENT PER BRIDGE ELEMENT 20 10 10 (A) . ) TJ=100 C 0 A .( 1 CURRENT 1 ARD CURRENT W FOR Tj=250C REVERSE PULSE WIDTH-300 S 2% DUTY CYCLE 0.1 ANEOUS 0.1 ANT ANEOUS INST ANT TJ=25 C 0 INST 0.01 0.01 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 0 20 40 60 80 100 120 140 INSTANTANEOUS FORWARD VOLTAGE. (V) PERCENT OF RATED PEAK REVERSE VOLTAGE. (%)
- 667 -
Document Outline 666.eps 667-2W005M THRU 2W10M.eps
