Datasheet RS1A, RS1B, RS1D, RS1G, RS1J, RS1K, RS1M (Unisonic Technologies) - 4
ManufacturerUnisonic Technologies
DescriptionSurface Mount Fast Recovery Rectifier
Pages / Page4 / 4 — RS1A THRU RS1M. DIODE. TYPICAL CHARACTERISTICS. UNISONIC TECHNOLOGIES …
File Format / SizePDF / 161 Kb
RS1A THRU RS1M. DIODE. TYPICAL CHARACTERISTICS. UNISONIC TECHNOLOGIES CO., LTD. www.unisonic.com.tw
RS1A THRU RS1M DIODE TYPICAL CHARACTERISTICS UNISONIC TECHNOLOGIES CO., LTD www.unisonic.com.tw
Forward Current Derating Curve Maximum Non-Repetitive Surge Current 1.0 40 ) A (A nt ( 0.8 nt 30 rre u urre C C e rd g 0.6 20 orwa F e ard Sur rw 0.4 o 10 erag F Pulse Width 3.3ms Av Single Phase Half Wave 60Hz ak Single Half-Sine-Wave Resistive or Inductive Load Pe (JEDEC Method) 0.2 0 25 50 75 100 125 150 175 1 2 5 10 20 50 100 Ambient Temperature (°C) Number of Cycles at 60Hz Typical Junction Capacitance Typical Forward Characteristics 100 10 (A) ent RS1A-RS1G rr u 1 (pF) ard C ce rw 10 RS1J-RS1M o F citan TJ=25°C us apa T 0.1 J=25°C, f=1MHz C aneo tant Pulse Width 300μs Ins 1 0.01 1 4 10 100 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 Reverse Voltage (v) Instantaneous Forward Voltage (V) UTC assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all UTC products described or contained herein. UTC products are not designed for use in life support appliances, devices or systems where malfunction of these products can be reasonably expected to result in personal injury. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. UTC reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof.
4 of 4
www.unisonic.com.tw
QW-R601-221.D
