Datasheet SB3H90, SB3H100 (Vishay) - 2
ManufacturerVishay
DescriptionHigh Voltage Schottky Plastic Rectifier
Pages / Page4 / 2 — SB3H90, SB3H100. ELECTRICAL CHARACTERISTICS. PARAMETER. TEST CONDITIONS. …
File Format / SizePDF / 76 Kb
SB3H90, SB3H100. ELECTRICAL CHARACTERISTICS. PARAMETER. TEST CONDITIONS. SYMBOL. SB3H90. SB3H100. UNIT. Notes. THERMAL CHARACTERISTICS
SB3H90, SB3H100 ELECTRICAL CHARACTERISTICS PARAMETER TEST CONDITIONS SYMBOL SB3H90 SB3H100 UNIT Notes THERMAL CHARACTERISTICS
SB3H90, SB3H100
www.vishay.com Vishay General Semiconductor
(TA = 25 °C unless otherwise noted)
Maximum instantaneous TJ = 25 °C 0.80 I V V forward voltage F = 3.0 A F (1) TJ = 125 °C 0.65 Maximum reverse current TJ = 25 °C 20 μA I at rated V R (2) R TJ = 125 °C 4.0 mA
Notes
(1) Pulse test: 300 μs pulse width, 1 % duty cycle (2) Pulse test: Pulse width  40 ms
PARAMETER SYMBOL SB3H90 SB3H100 UNIT
RJA (1) 50 Maximum thermal resistance °C/W RJL (1) 20
Note
(1) PCB mounted with 0.2" x 0.2" (5.0 mm x 5.0 mm) copper pad areas
ORDERING INFORMATION
(Example)
PREFERRED P/N UNIT WEIGHT (g) PREFERRED PACKAGE CODE BASE QUANTITY DELIVERY MODE
SB3H100-E3/54 1.09 54 1400 13" diameter paper tape and reel SB3H100-E3/73 1.09 73 1000 Ammo pack packaging
RATINGS AND CHARACTERISTICS CURVES
(TA = 25 °C unless otherwise noted) 4.0 100 T = T Max. Resistive or Inductive Load J J 8.3 ms Single Half Sine-Wave 0.375" (9.5 mm) Lead Length 80 3.0 ent (A) ent (A) 60 d Curr ge Curr 2.0 ur S d 40 1.0 verage Forwar 20 A Peak Forwar 0 10 0 25 50 75 100 125 150 175 1 10 100 Lead Temperature (°C) Number of Cycles at 60 Hz Fig. 1 - Forward Current Derating Curve Fig. 2 - Maximum Non-Repetitive Peak Forward Surge Current Revision: 13-Aug-13
2
Document Number: 88720 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
