Datasheet MAX3280E, MAX3281E, MAX3283E, MAX3284E (Analog Devices) - 5
Description | ±15kV ESD-Protected 52Mbps, 3V to 5.5V, SOT23 RS-485/RS-422 True Fail-Safe Receivers |
Pages / Page | 11 / 5 — Typical Operating Characteristics (continued). RECEIVER OUTPUT LOW … |
Typical Operating Characteristics (continued). RECEIVER OUTPUT LOW VOLTAGE. RECEIVER PROPAGATION DELAY (tPLH)
MAX3280E/MAX3281E/ ±15kV ESD-Protected 52Mbps, 3V to 5.5V, MAX3283E/MAX3284E SOT23 RS-485/RS-422 True Fail-Safe Receivers
(VCC = 3.3V, TA = +25°C, unless otherwise noted.)
RECEIVER OUTPUT LOW VOLTAGE RECEIVER PROPAGATION DELAY (tPLH) RECEIVER PROPAGATION DELAY (tPHL) vs. TEMPERATURE vs. TEMPERATURE vs. TEMPERATURE
200 9 10 8 150 9 MAX3280/1/3/4E toc04 MAX3280/1/3/4E toc05 MAX3280/1/3/4E toc06 VCC = 3.3V VCC = 5V 7 VCC = 5V (ns) (ns) 100 VCC = 5V V 8 t PLH CC = 3.3V t PHL VCC = 3.3V 6 50 7 5 RECEIVER OUTPUT LOW VOLTAGE (mV) A = GND, VB = 1V, IOL = 4mA 0 4 6 -50 -25 0 25 50 75 100 125 -50 -25 0 25 50 75 100 125 -50 -25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C)
MAX3284E MAXIMUM DATA RATE SUPPLY CURRENT vs. TEMPERATURE vs. VOLTAGE LOGIC LEVEL
9 60 VCC = 5V 8 50 MAX3280/1/3/4E toc07 MAX3280/1/3/4E toc08 7 40 DATA RATE (Mbps) SUPPLY CURRENT (mA) 6 30 VCC = 3.3V 5 20 -50 -25 0 25 50 75 100 125 1.5 2.5 3.5 4.5 5.5 TEMPERATURE (°C) VOLTAGE LOGIC LEVEL (V)
VL SUPPLY CURRENT SUPPLY CURRENT vs. DATA RATE vs. TEMPERATURE
10 10 ICC, VCC = VL = 5V 8 1 VCC = VL = 5V MAX3280/1/3/4 toc10 MAX3280/1/3/4E toc09 DATA RATE = 52Mbps VCC = VL = 3.3V ICC, VCC = VL = 3.3V DATA RATE = 52Mbps 6 0.1 IL, VCC = VL = 5V 4 VCC = VL = 5V SUPPLY CURRENT (mA) DATA RATE = 100kbps SUPPLY CURRENT (mA) V L 0.01 2 VCC = VL = 3.3V IL, VCC = VL = 3.3V DATA RATE = 100kbps 0.001 0 -50 -25 0 25 50 75 100 125 10 100 1000 10,000 100,000 TEMPERATURE (°C) DATA RATE (kbps) www.maximintegrated.com Maxim Integrated │
5
