Datasheet MAX4091, MAX4092, MAX4094 (Maxim) - 4
Manufacturer | Maxim |
Description | Single/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps |
Pages / Page | 16 / 4 — Single/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps. … |
File Format / Size | PDF / 527 Kb |
Single/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps. Typical Operating Characteristics. GAIN AND PHASE
Single/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps Typical Operating Characteristics
(VCC = 5V, VEE = 0, TA = +25°C, unless otherwise noted.)
GAIN AND PHASE GAIN AND PHASE POWER-SUPPLY REJECTION RATIO vs. FREQUENCY vs. FREQUENCY vs. FREQUENCY
MAX4091 toc01 MAX4091 toc02 80 180 80 180 140 AV = 1000 CL = 470pF VIN = 2.5V NO LOAD AV = 1000 120 60 120 60 120 RL = ∞ MAX4091 toc03 V GAIN CC 100 GAIN 40 60 40 60 80 20 PHASE 0 20 0 60 PHASE GAIN (dB) GAIN (dB) PHASE (DEGREES) PSRR (dB) 40 VEE 0 -60 PHASE (DEGREES) 0 -60 20 -20 -120 -20 -120 0 -40 -180 -40 -180 -20 0.01 0.1 1 10 100 1000 10,000 0.01 0.1 1 10 100 1000 10,000 0.01 0.1 1 10 100 1000 FREQUENCY (kHz) FREQUENCY (kHz) FREQUENCY (kHz)
CHANNEL ISOLATION OFFSET VOLTAGE OFFSET VOLTAGE vs. vs. FREQUENCY vs. TEMPERATURE COMMON-MODE VOLTAGE
140 160 100 V V IN = 2.5V CM = 0 80 120 140 MAX4901 toc04 MAX4091 toc05 MAX4091 toc06 60 120 100 mV) µV) 40 100 VCC = 2.7V
MAX4091/MAX4092/MAX4094
80 20 80 0 60 60 -20 40 V OFFSET VOLTAGE ( OFFSET VOLTAGE ( -40 CC = 6V 40 CHANNEL SEPARATION (dB) -60 20 20 -80 0 0 -100 0.01 0.1 1 10 100 1000 10,000 -60 -40 -20 0 20 40 60 80 100 120 140 -1 0 1 2 3 4 5 6 7 FREQUENCY (kHz) TEMPERATURE (°C) COMMON-MODE VOLTAGE (V)
COMMON-MODE REJECTION RATIO INPUT BIAS CURRENT vs. INPUT BIAS CURRENT vs. vs. TEMPERATURE COMMON-MODE VOLTAGE TEMPERATURE
110 25 40 VCC = 6V VCM = 0 TO 5V 20 30 V 100 CC = 6V V V CM = -0.1V TO +5.1V CM = VCC MAX4091 toc07 MAX4091 toc08 15 MAX4091 toc09 VCC = 2.7V 20 10 90 5 10 VCC = 2.7V 80 0 0 CMRR (dB) -5 -10 70 VCM = -0.2V TO +5.2V -10 INPUT BIAS CURRENT (nA) INPUT BIAS CURRENT (nA) V -20 CM = -0.3V TO +5.3V -15 V 60 CM = 0 VCM = -0.4V TO +5.4V -20 -30 VCC = 6V 50 -25 -40 -60 -40 -20 0 20 40 60 80 100 120 140 0 1 2 3 4 5 6 -50 -25 0 25 50 75 100 125 TEMPERATURE (°C) COMMON-MODE VOLTAGE (V) TEMPERATURE (°C)
4 _______________________________________________________________________________________
