link to page 1 link to page 1 link to page 1 TS555 Low-power single CMOS timer Datasheet - production dataDescription The TS555 is a single CMOS timer with very low consumption: SO8 (Icc(TYP) TS555 = 110 µA at VCC = +5 V versus (plastic micropackage) Icc(TYP) NE555(a) = 3 mA), and high frequency: (ff(max.) TS555 = 2.7 MHz versus Pin connections f(max) NE555(a) = 0.1 MHz). (top view) Timing remains accurate in both monostable and astable mode. *1' && 9 The TS555 provides reduced supply current 7ULJJHU 'LVFKDUJH spikes during output transitions, which enable the 2XWSXW 7KUHVKROG use of lower decoupling capacitors compared to 5HVHW &RQWURO 9ROWDJH those required by bipolar NE555(a). With the high input impedance (1012Ω), timing capacitors can also be minimized. Features • Very low power consumption: – 110 µA typ at VCC = 5 V – 90 µa typ at VCC = 3 V • High maximum astable frequency of 2.7 MHz • Pin-to-pin functionally-compatible with bipolar NE555(a) • Wide voltage range: +2 V to +16 V • Supply current spikes reduced during output transitions • High input impedance: 1012 Ω • Output compatible with TTL, CMOS and logic MOS a. Terminated product June 2015 DocID4077 Rev 4 1/19 This is information on a product in full production. www.st.com Document Outline 1 Absolute maximum ratings and operating conditions Table 1. Absolute maximum ratings Table 2. Operating conditions 2 Schematic diagrams Figure 1. Schematic diagram Figure 2. Block diagram Table 3. Functional table 3 Electrical characteristics Table 4. Static electrical characteristics VCC = +2 V, Tamb = +25 °C, reset to VCC (unless otherwise specified) Table 5. Static electrical characteristics VCC = +3 V, Tamb = +25 °C, reset to VCC (unless otherwise specified) Table 6. Dynamic electrical characteristics VCC = +3 V, Tamb = +25 °C, reset to VCC (unless otherwise specified) Table 7. Static electrical characteristics VCC = +5 V, Tamb = +25 °C, reset to VCC (unless otherwise specified) Table 8. Dynamic electrical characteristics VCC = +5 V, Tamb = +25 °C, reset to VCC (unless otherwise specified) Table 9. Static electrical characteristics VCC = +12 V, Tamb = +25 °C, reset to VCC (unless otherwise specified) Table 10. Dynamic electrical characteristics VCC = +12 V, Tamb = +25 °C, reset to VCC (unless otherwise specified) Figure 3. Supply current (per timer) versus supply voltage 4 Application information 4.1 Monostable operation Figure 4. Application schematic Figure 5. Timing diagram 4.2 Astable operation Figure 6. Application schematic Figure 7. Timing diagram 5 Package information 5.1 SO8 package information Figure 8. SO8 package outline Table 11. SO8 mechanical data 6 Ordering information Table 12. Order code table 7 Revision history Table 13. Document revision history
