Datasheet TS555 (STMicroelectronics) - 10
Manufacturer | STMicroelectronics |
Description | Low-power single CMOS timer |
Pages / Page | 19 / 10 — Electrical characteristics. TS555. Table 8. Dynamic electrical … |
File Format / Size | PDF / 434 Kb |
Electrical characteristics. TS555. Table 8. Dynamic electrical characteristics
link to page 13 link to page 10 link to page 10 link to page 14 link to page 10 link to page 10
Electrical characteristics TS555
m
Table 8. Dynamic electrical characteristics VCC = +5 V, Tamb = +25 °C, reset to VCC (unless otherwise specified) Symbol Parameter Min. Typ. Max. Unit
Timing accuracy (monostable) (1) % R = 10 kΩ, C = 0.1 µF 2 Timing shift with supply voltage variations (monostable) (1) %/V R = 10 kΩ, C = 0.1 µF,VCC = 5 V ± 1 V 0.38 Timing shift with temperature (1) ppm/°C Tmin ≤ Tamb ≤ Tmax5 75 Maximum astable frequency (2) fmax MHz RA = 470 Ω, RB = 200 Ω, C = 200 pF 2.7 — — Astable frequency accuracy (2) % RA = RB = 1 kΩ to 100 kΩ, C = 0.1 µF 3 Timing shift with supply voltage variations (astable mode) (2) %/V RA = RB = 10 kΩ, C = 0.1 µF, VCC = 5 to 12 V 0.1 tR Output rise time (Cload = 10 pF) 25 tF Output fall time (Cload = 10 pF) 20 ns tPD Trigger propagation delay 100 tRPW Minimum reset pulse width (Vtrig = 5 V) 350 1. See Figure 4 2. See Figure 6 10/19 DocID4077 Rev 4 Document Outline 1 Absolute maximum ratings and operating conditions Table 1. Absolute maximum ratings Table 2. Operating conditions 2 Schematic diagrams Figure 1. Schematic diagram Figure 2. Block diagram Table 3. Functional table 3 Electrical characteristics Table 4. Static electrical characteristics VCC = +2 V, Tamb = +25 °C, reset to VCC (unless otherwise specified) Table 5. Static electrical characteristics VCC = +3 V, Tamb = +25 °C, reset to VCC (unless otherwise specified) Table 6. Dynamic electrical characteristics VCC = +3 V, Tamb = +25 °C, reset to VCC (unless otherwise specified) Table 7. Static electrical characteristics VCC = +5 V, Tamb = +25 °C, reset to VCC (unless otherwise specified) Table 8. Dynamic electrical characteristics VCC = +5 V, Tamb = +25 °C, reset to VCC (unless otherwise specified) Table 9. Static electrical characteristics VCC = +12 V, Tamb = +25 °C, reset to VCC (unless otherwise specified) Table 10. Dynamic electrical characteristics VCC = +12 V, Tamb = +25 °C, reset to VCC (unless otherwise specified) Figure 3. Supply current (per timer) versus supply voltage 4 Application information 4.1 Monostable operation Figure 4. Application schematic Figure 5. Timing diagram 4.2 Astable operation Figure 6. Application schematic Figure 7. Timing diagram 5 Package information 5.1 SO8 package information Figure 8. SO8 package outline Table 11. SO8 mechanical data 6 Ordering information Table 12. Order code table 7 Revision history Table 13. Document revision history
