Datasheet LMC7221 (Texas Instruments) - 2
Description | Tiny CMOS Comparator with Rail-To-Rail Input and Open Drain Output |
Pages / Page | 24 / 2 — LMC7221. www.ti.com. Absolute Maximum Ratings (1). Operating Ratings (1). … |
File Format / Size | PDF / 924 Kb |
LMC7221. www.ti.com. Absolute Maximum Ratings (1). Operating Ratings (1). 2.7V Electrical Characteristics. Boldface. Parameter
LMC7221
SNOS748E – SEPTEMBER 1999 – REVISED MARCH 2013
www.ti.com Absolute Maximum Ratings (1)
ESD Tolerance (2) 2 kV Differential Input Voltage V+ +0.3V, V− −0.3V Voltage at Input V+ +0.3V, V− −0.3V Voltage at Output Pin 15V Supply Voltage (V+–V−) 16V Current at Input Pin (3) ±5 mA Current at Output Pin(4) (5) ±30 mA Current at Power Supply Pin 40 mA Lead Temperature (soldering, 10 sec.) 260°C Junction Temperature (6) 150°C (1) Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. Operating Ratings indicate conditions for which the device is intended to be functional, but specific performance is not ensured. For ensured specifications and the test conditions, see the Electrical Characteristics. (2) Human Body Model, applicable std. MIL-STD-883, Method 3015.7. Machine Model, applicable std. JESD22-A115-A (ESD MM std. of JEDEC)Field-Induced Charge-Device Model, applicable std. JESD22-C101-C (ESD FICDM std. of JEDEC). (3) All limits are specified by testing or statistical analysis. (4) Applies to both single-supply and split-supply operation. Continuous short circuit operation at elevated ambient temperature can result in exceeding the maximum allowed junction temperature of 150°C. Output currents in excess of ±30 mA may adversely affect reliability. (5) Limiting input pin current is only necessary for input voltages which exceed the absolute maximum input voltage rating. (6) The maximum power dissipation is a function of TJ(MAX), θJA. The maximum allowable power dissipation at any ambient temperature is PD = (TJ(MAX) – TA)/ θJA. All numbers apply for packages soldered directly onto a PC Board.
Supply Voltage 2.7 ≤ VCC ≤ 15V Temperature Range (2) LMC7221AI, LMC7221BI −40°C to +85°C Thermal Resistance (θJA) 8-Pin SOIC 180°C/W 5-Pin SOT-23 325°C/W (1) Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. Operating Ratings indicate conditions for which the device is intended to be functional, but specific performance is not ensured. For ensured specifications and the test conditions, see the Electrical Characteristics. (2) The maximum power dissipation is a function of TJ(MAX), θJA. The maximum allowable power dissipation at any ambient temperature is PD = (TJ(MAX) – TA)/ θJA. All numbers apply for packages soldered directly onto a PC Board.
Unless otherwise specified, all limits ensured for TJ = 25°C, V+ = 2.7V, V− = 0V, VCM = VO = V+/2.
Boldface
limits apply at the temperature extremes.
Parameter Test Conditions LMC7221AI LMC7221BI Units Typ(1) Limit(2) Limit(2)
VOS Input Offset Voltage 3 5 15 mV
8 18
max TCVOS Input Offset Voltage 1.0 μV/°C Temperature Drift Input Offset Voltage Average (3) 3.3 μV/Month Drift IB Input Current 0.04 pA IOS Input Offset Current 0.02 pA CMRR Common Mode Rejection Ratio 0V ≤ VCM ≤ 2.7V 75 dB PSRR Power Supply Rejection Ratio 2.7V ≤ V+ ≤ 15V 80 dB (1) Typical values represent the most likely parametric norm as determined at the time of characterization. Actual typical values may vary over time and will also depend on the application and configuration. The typical values are not tested and are not ensured on shipped production material. (2) All limits are specified by testing or statistical analysis. (3) CL includes the probe and test jig capacitance. 2 Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LMC7221 Document Outline FEATURES Applications DESCRIPTION Connection Diagram Absolute Maximum Ratings Operating Ratings 2.7V Electrical Characteristics 5.0V and 15.0V Electrical Characteristics Leakage Characteristics AC Electrical Characteristics Typical Performance Characteristics Application Information BENEFITS OF THE LMC7221 TINY COMPARATOR Size Height Simplified Board Layout Low Supply Current Wide Voltage Range Digital Outputs Representing Signal Level Open Drain Output Driving LEDs (Light Emitting Diodes) Input range to Beyond Rail to Rail Zero Crossing Detector Low Input Currents and High Input Impedance Direct Sensor Interfacing LOW VOLTAGE OPERATION OPEN DRAIN OUTPUT Output Stage OUTPUT SHORT CIRCUIT CURRENT INPUT PROTECTION LAYOUT CONSIDERATIONS PUSH-PULL OUTPUTS, DUAL VERSIONS ADDITIONAL 5-Pin SOT-23 TINY DEVICES SPICE MACROMODEL Revision History
