500MHz to 2500MHzVCO Buffer AmplifiersMAX2472/MAX2473AC ELECTRICAL CHARACTERISTICS—MAX2472 (continued) (Typical Operating Circuits, VCC = +3V, PIN = -25dBm, IN driven from a 50Ω source, OUT1 and OUT2 LC matched to 50Ω, TA = +25°C, unless otherwise noted.) PARAMETERSYMBOLCONDITIONSMINTYPMAXUNITS fIN = 600MHz 54 Reverse Isolation fIN = 900MHz 49 S122 dB (IN to OUT1) fIN = 1900MHz 34 fIN = 2400MHz 30 fIN = 900MHz 9.5 Noise Figure NF dB fIN = 1900MHz 10.2 Isolation (OUT1 to OUT2) fIN = 900MHz 24 dB Harmonic Suppression POUT = -5dBm, fIN = 900MHz -25 dBc AC ELECTRICAL CHARACTERISTICS—MAX2473 (Typical Operating Circuits, VCC = +3V, PIN = -25dBm, RBIAS = 15kΩ, IN driven from a 50Ω source, OUT LC matched to 50Ω, TA = +25°C, unless otherwise noted.) PARAMETERSYMBOLCONDITIONSMINTYPMAXUNITS Input Frequency Range (Note 2) fIN 500 2500 MHz fIN = 600MHz 14.8 fIN = 900MHz, TA = +25°C 6.8 11.8 16.8 Transducer Gain S212 fIN = 900MHz, TA = TMIN to TMAX (Note 3) 6.4 19.0 dB fIN = 1900MHz 7.6 fIN = 2400MHz 7.2 RBIAS = 23kΩ -6.0 Output 1dB Compression Point POUT1dB fIN = 900MHz dBm RBIAS = 11kΩ -0.9 fIN = 600MHz 50 fIN = 900MHz Reverse Isolation 48 S122 dB fIN = 1900MHz 35 fIN = 2400MHz 29 fIN = 900MHz 9.2 Noise Figure NF dB fIN = 1900MHz 9.9 Harmonic Suppression POUT = -5dBm, fIN = 900MHz -25 dBc Note 1: Limits are 100% production tested at TA = +25°C. Limits over the entire operating temperature range are guaranteed by design and characterization but are not production tested. Note 2: This is the recommended operating frequency range. The parts have been characterized over the specified frequency range and production tested at 900MHz. Operation outside of this range is possible but not guaranteed. Note 3: Guaranteed by design and characterization. _______________________________________________________________________________________3
