Datasheet MAX2472, MAX2473 (Analog Devices) - 4
Description500MHz to 2500MHz VCO Buffer Amplifiers
Pages / Page12 / 4 — 500MHz to 2500MHz VCO Buffer Amplifiers. Typical Operating …
File Format / SizePDF / 248 Kb
500MHz to 2500MHz VCO Buffer Amplifiers. Typical Operating Characteristics. MAX2472. SUPPLY CURRENT vs. TEMPERATURE
500MHz to 2500MHz VCO Buffer Amplifiers Typical Operating Characteristics MAX2472 SUPPLY CURRENT vs TEMPERATURE
(MAX2472/MAX2473 EV kit, VCC = +3V, TA = +25°C, unless otherwise noted.)
MAX2472 SUPPLY CURRENT vs. TEMPERATURE S21 2 vs. TEMPERATURE
7.0 PIN = -20dBm 14 fIN = 600MHz PIN = -20dBm fIN = 900MHz MAX2472 toc01 12 MAX2472 toc02 6.0 10 fIN = 900MHz VCC = 5V (dB) 8 (mA) 2 fIN = 1900MHz I CC V S 21 CC = 3V 6 5.0 4 fIN = 2400MHz 2
MAX2472/MAX2473
4.0 0 -40 -20 0 20 40 60 80 -50 -30 -10 10 30 50 70 90 TEMPERATURE (°C) TEMPERATURE (°C)
S21 2 vs. OUTPUT POWER S11
14 fIN = 600MHz 12 MAX2472 toc03 MAX2472 toc06 10 fIN = 900MHz fIN = 1900MHz (dB) 8 2 S 21 6 fIN = 2400MHz A D B 4 C 2 FOR OUT1 WITH OUT2 REACTIVELY MATCHED AND TERMINATED 0 A: fIN = 600MHz -20 -18 -16 -14 -12 -10 -8 -6 -4 -2 0 FOR OUT2 WITH OUT1 BIASED B: fIN = 900MHz P C: fIN = 1900MHz OUT (dBm) AND TERMINATED D: fIN = 2400MHz
S21 S12 S22
MAX2472 toc07 MAX2472 toc08 MAX2472 toc09 D BA C D A C B D B A C A: fIN = 600MHz A: fIN = 600MHz A: fIN = 600MHz B: f (3 UNITS FULL SCALE) B: fIN = 900MHz (0.1 UNITS FULL SCALE) B: fIN = 900MHz FOR OUT2 WITH OUT1 BIASED IN = 900MHz C: f FOR OUT2 WITH OUT1 BIASED C: fIN = 1900MHz FOR OUT2 WITH OUT1 BIASED C: fIN = 1900MHz AND TERMINATED IN = 1900MHz D: f AND TERMINATED D: fIN = 2400MHz AND TERMINATED D: fIN = 2400MHz IN = 2400MHz
4 _______________________________________________________________________________________
