Datasheet AV, SMV (Pico Electronics) - 2
Manufacturer | Pico Electronics |
Description | Isolated DC-DC Converters |
Pages / Page | 7 / 2 — OPTIONS AVAILABLE. Note:. Converter frequency:. Output temperature … |
File Format / Size | PDF / 309 Kb |
OPTIONS AVAILABLE. Note:. Converter frequency:. Output temperature coefficient:. Operating temperature:. Storage temperature:
OPTIONS AVAILABLE Note:
For tighter output voltage tolerances, please consult factory.
20 - 40 KHz Selected Per Mil. Std. 883
0.02%/ºC for all models Expanded operating temp (-55º C to +85º C)
-25º C to +70º C ambient. No heat sink is Stabilization Bake (+125º C ambient) required. Temperature Cycle (-55º C to +125º C)
-55º C to +125º C Hi Temp, full power burn in (100% power, 125º C case temp)
Isolation:
100 megohms min. @ 1000V DC
SERIES AV/SMV - SINGLE OUTPUT * ** Input PICO Eff. @ PICO Max. Max. Current Output Full Surface Input Output Full Plug-in Load Output Full Volt. Load Mount Volt. Volt. Load Part Current Power Load Ripple Output Price Part (V DC) (V DC) Typical @ Full Volt. Number (mA) (watts) Typical Number (%) Load Tolerance (mA) (Vp-p max) (± %)
5AV100 5SMV100 5 100 12.50 1.25 76 321 0.90 3 85.73 5AV150 5SMV150 5 150 8.30 1.25 76 329 0.90 3 85.73 5AV200 5SMV200 5 200 6.25 1.25 75 333 0.90 3 85.73 5AV250 5SMV250 5 250 5.00 1.25 75 333 0.90 3 85.73 5AV300 5SMV300 5 300 4.16 1.25 70 357 1.20 3 105.93 5AV350 5SMV350 5 350 3.57 1.25 70 357 1.20 3 105.93 5AV400 5SMV400 5 400 3.12 1.25 70 357 1.20 3 105.93 5AV450 5SMV450 5 450 2.77 1.25 70 357 1.50 3 105.93 5AV500 5SMV500 5 500 2.50 1.25 70 357 1.50 3 105.93 12AV100 12SMV100 12 100 12.50 1.25 80 130 0.90 3 85.73 12AV150 12SMV150 12 150 8.30 1.25 79 132 0.90 3 85.73 12AV200 12SMV200 12 200 6.25 1.25 78 134 0.90 3 85.73 12AV250 12SMV250 12 250 5.00 1.25 75 139 0.90 3 85.73 12AV300 12SMV300 12 300 4.16 1.25 75 139 1.20 3 105.93 12AV350 12SMV350 12 350 3.57 1.25 75 139 1.20 3 105.93 12AV400 12SMV400 12 400 3.12 1.25 75 139 1.20 3 105.93 12AV450 12SMV450 12 450 2.77 1.25 75 139 1.50 3 105.93 12AV500 12SMV500 12 500 2.50 1.25 75 139 1.50 3 105.93 15AV100 15SMV100 15 100 12.50 1.25 80 104 0.90 3 85.73 15AV150 15SMV150 15 150 8.30 1.25 79 105 0.90 3 85.73 15AV200 15SMV200 15 200 6.25 1.25 78 107 0.90 3 85.73 15AV250 15SMV250 15 250 5.00 1.25 75 111 0.90 3 85.73 15AV300 15SMV300 15 300 4.16 1.25 75 111 1.20 3 105.93 15AV350 15SMV350 15 350 3.57 1.25 75 111 1.20 3 105.93
