Datasheet MM74C925, MM74C926, MM74C927, MM74C928 (Fairchild)
ManufacturerFairchild
Description4-Digit Counters with Multiplexed 7-Segment Output Drivers
Pages / Page9 / 1 — MM74C925. • MM74C926. MM74C925 • MM74C926 • MM74C927 • MM74C928 4-Digit …
File Format / SizePDF / 112 Kb
MM74C925. • MM74C926. MM74C925 • MM74C926 • MM74C927 • MM74C928 4-Digit Counters with Multiplexed 7-Segment Output Drivers
Datasheet MM74C925, MM74C926, MM74C927, MM74C928 Fairchild
MM74C925
October 1987 Revised January 1999
• MM74C926 MM74C925 • MM74C926 • MM74C927 • MM74C928 4-Digit Counters with Multiplexed 7-Segment Output Drivers General Description
back LOW only when the counter is reset. Thus, this is a 3½-digit counter.
• MM74C927
The MM74C925, MM74C926, MM74C927 and MM74C928 CMOS counters consist of a 4-digit counter, an internal out-
Features
put latch, NPN output sourcing drivers for a 7-segment dis- play, and an internal multiplexing circuitry with four ■ Wide supply voltage range: 3V to 6V multiplexing outputs. The multiplexing circuit has its own ■ Guaranteed noise margin: 1V free-running oscillator, and requires no external clock. The ■ High noise immunity: 0.45 V counters advance on negative edge of clock. A HIGH sig- CC (typ.) nal on the Reset input will reset the counter to zero, and ■ High segment sourcing current: 40 mA
• MM74C928 4
reset the carry-out LOW. A LOW signal on the Latch @ VCC − 1.6V, VCC = 5V Enable input will latch the number in the counters into the ■ Internal multiplexing circuitry internal output latches. A HIGH signal on Display Select input will select the number in the counter to be displayed;
Design Considerations
a LOW level signal on the Display Select will select the number in the output latch to be displayed. Segment resistors are desirable to minimize power dissipa- The MM74C925 is a 4-decade counter and has Latch tion and chip heating. The DS75492 serves as a good digit Enable, Clock and Reset inputs. driver when it is desired to drive bright displays. When using this driver with a 5V supply at room temperature, the
The MM74C926 is like the MM74C925 except that it has a
Di
display can be driven without segment resistors to full illu- display select and a carry-out used for cascading counters.
git
mination. The user must use caution in this mode however, The carry-out signal goes HIGH at 6000, goes back LOW to prevent overheating of the device by using too high a
Count
at 0000. supply voltage or by operating at high ambient tempera- The MM74C927 is like the MM74C926 except the second tures. most significant digit divides by 6 rather than 10. Thus, if The input protection circuitry consists of a series resistor, the clock input frequency is 10 Hz, the display would read and a diode to ground. Thus input signals exceeding VCC
er
tenths of seconds and minutes (i.e., 9:59.9). will not be clamped. This input signal should not be allowed
s wi
The MM74C928 is like the MM74C926 except the most sig- to exceed 15V. nificant digit divides by 2 rather than 10 and the carry-out is an overflow indicator which is HIGH at 2000, and it goes
th M u Ordering Code: ltiple Order Number Package Number Package Description x
MM74C925N N16E 16-Lead Plastic Dual-In-Line Package (PDIP), JEDEC MS-001, 0.300” Wide
ed
MM74C926N N18A 18-Lead Plastic Dual-In-Line Package (PDIP), JEDEC MS-001, 0.300” Wide
7-Se
MM74C927N N18A 18-Lead Plastic Dual-In-Line Package (PDIP), JEDEC MS-001, 0.300” Wide MM74C928N N18A 18-Lead Plastic Dual-In-Line Package (PDIP), JEDEC MS-001, 0.300” Wide
gm ent Out put Dri ver s
© 1999 Fairchild Semiconductor Corporation DS005919.prf www.fairchildsemi.com
