Datasheet MM74C925, MM74C926, MM74C927, MM74C928 (Fairchild) - 9
ManufacturerFairchild
Description4-Digit Counters with Multiplexed 7-Segment Output Drivers
Pages / Page9 / 9 — MM74C925. Physical Dimensions. • MM74C926. • MM74C927. • MM74C928 4. -Di
File Format / SizePDF / 112 Kb
MM74C925 Physical Dimensions • MM74C926 • MM74C927 • MM74C928 4 -Di
inches (millimeters) unless otherwise noted (Continued)
• MM74C926 • MM74C927 • MM74C928 4 -Di 18-Lead Plastic Dual-In-Line Package (PDIP), JEDEC MS-001, 0.300” Wide Package Number N18A git Count er s wi th M u ltiplexed 7-Se gm LIFE SUPPORT POLICY ent
FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT
Out
DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF THE PRESIDENT OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein:
put
1. Life support devices or systems are devices or systems 2. A critical component in any component of a life support which, (a) are intended for surgical implant into the device or system whose failure to perform can be rea- body, or (b) support or sustain life, and (c) whose failure sonably expected to cause the failure of the life support
Dri
to perform when properly used in accordance with device or system, or to affect its safety or effectiveness.
ver
instructions for use provided in the labeling, can be rea- sonably expected to result in a significant injury to the
www.fairchildsemi.com s
user. Fairchild does not assume any responsibility for use of any circuitry described, no circuit patent licenses are implied and Fairchild reserves the right at any time without notice to change said circuitry and specifications.
