Datasheet TRU (Tai-Shing)
ManufacturerTai-Shing
DescriptionElectromechanical Relay
Pages / Page2 / 1 — TRU. MAIN FEATURES. APPLICATIONS. ORDERING INFORMATION. …
File Format / SizePDF / 431 Kb
TRU. MAIN FEATURES. APPLICATIONS. ORDERING INFORMATION. DIMENSION(unit:mm). DRILLING(unit:mm). WIRING DIAGRAM
Datasheet TRU Tai-Shing
TRU
TRU
TRUT with TV-10 Approval ▓
MAIN FEATURES
High contact capacity : 12A, 15A Employment of suitable plastic materials to be applied to high temperature and various chemical solution. Sealed types available. UL、CSA and TUV recognized. ▓
TRU : Home appliance, air conditioner, heater, etc. Automotive Power-window, car antenna, door-lock, etc. Office machine, facsimile, etc. Vending machine. TRUT : Remote control TV receivers, monitor displays, audio equipment high rushing current use application. ▓
Nominal coil voltage : 3V, 5V, 6V, 9V, 12V, 24V, 48V Type Structure F : Flux Free Type S : Washable Type TRU 12V DC F B C L R R : RoHS Compliant Add suffix "R" for RoHS compliant only use for order indentify not use for safety certified Coil Resistance D : Standard L : High Sensitive Contact Rating Contact material Contact Arrangent A : 1 Form A Nil : Standard B : AgCdO C : 1 Form C T : TV-10 Rating C : AgSnIn (For RoHS) (Form A only) ■
DIMENSION(unit:mm)
DRILLING(unit:mm)
WIRING DIAGRAM
TRU Form A AND TRUT (TV-10) TYPE N.O COM COIL TRU Form C TYPE N.O COM COIL N.C
Tai-Shing Electronic Components Corp. www.tai-shing.com.tw
49
