Datasheet BCX42 (Infineon)
ManufacturerInfineon
DescriptionNPN Silicon AF and Switching Transistor
Pages / Page7 / 1 — BCX42. PNP Silicon AF and Switching Transistor. Type. Marking. Pin …
File Format / SizePDF / 539 Kb
BCX42. PNP Silicon AF and Switching Transistor. Type. Marking. Pin Configuration. Package. Maximum Ratings Parameter. Symbol. Value. Unit
Datasheet BCX42 Infineon
BCX42 PNP Silicon AF and Switching Transistor
• For general AF applications 3 2 • High breakdown voltage 1 • Low collector-emitter saturation voltage • Complementary type: BCX41 (NPN) • Pb-free (RoHS compliant) package • Qualified according AEC Q101
Type Marking Pin Configuration Package
BCX42 DKs 1 = B 2 = E 3 = C SOT23
Maximum Ratings Parameter Symbol Value Unit
Collector-emitter voltage VCEO 125 V Collector-base voltage VCBO 125 Emitter-base voltage VEBO 5 Collector current IC 800 mA Peak collector current, tp ≤ 10 ms ICM 1 A Base current IB 100 mA Peak base current IBM 200 Total power dissipation Ptot 330 mW TS ≤ 79 °C Junction temperature Tj 150 °C Storage temperature Tstg -65 ... 150
Thermal Resistance Parameter Symbol Value Unit
Junction - soldering point1) RthJS ≤ 215 K/W 1For calculation of RthJA please refer to Application Note AN077 (Thermal Resistance Calculation) 1 2011-10-04
