Datasheet TS2431 (STMicroelectronics) - 4
DescriptionAdjustable Shunt Voltage Reference
Pages / Page16 / 4 — Electrical characteristics. TS2431. Symbol. Parameter. Test conditions. …
File Format / SizePDF / 824 Kb
Electrical characteristics. TS2431. Symbol. Parameter. Test conditions. Min. Typ. Max. Unit. Notes:
Electrical characteristics TS2431 Symbol Parameter Test conditions Min Typ Max Unit Notes:
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 5
Electrical characteristics TS2431 2 Electrical characteristics Symbol Parameter Test conditions Min. Typ. Max. Unit
VK = VREF, IK = 10 2.5 mA TS2431 (2%) 2.45 2.55 Reference input VREF TS2431A (1%) 2.475 2.525 V voltage TS2431B (0.5%) 2.488 2.512 TS2431B (1%), IK 2.475 2.525 = 1 mA 0 °C < T < + 70 °C 10 20 Reference input voltage deviation -40 °C < T < + 85 17 30 |ΔVREF| over temperature °C mV VK = VREF, IK = 10 mA(1)(2) -40 °C < T < + 20 35 105 °C Temperature -40 °C < T < + TC 50 100 ppm/°C coefficient(2) 105 °C T = 25 °C 0.3 0.8 Minimum IKMIN mA operating current -40 °C < T < +105 1 °C Ratio of change in reference input |Δ𝑉𝑟𝑒𝑓| I voltage to change K = 10 mA Vka = Δ𝑉 0.3 2 mV/V 𝐾 24 to 2.5 V in cathode-to- anode voltage Reference input T = 25 °C 0.5 2.5 µA current I I K= 10 mA, REF R1 = 10 kΩ, R2 = -40 °C < T < +105 3 + ∞(3) °C Reference input |ΔI current deviation -40 °C < T < +105 REF| 0.4 1.2 µA IK = 10 mA, R1 = °C 10 kΩ, R2 = + ∞(3) Off-state cathode V I K = 24 V, VREF = OFF 10 500 nA current GND V Reverse dynamic K = VREF, ΔIK = 1 |ZKA| to 50 mA, f < 10 0.5 0.75 Ω impedance kHz I E K = 10 mA 10 Hz N Wide band noise 300 nV/√Hz < f < 10 kHz
Notes:
(1)Limits are 100 % production tested at 25 °C. Overtemperature limits are guaranteed through correlation and by design. (2)|ΔVREF| is defined as the difference between the maximum and minimum values of VREF obtained over the full temperature range. (3)Refer to Figure 4: "Test circuit for Vka = Vref". 4/16 DocID7961 Rev 6
