Datasheet ISL21080 (Renesas) - 2
Manufacturer | Renesas |
Description | 300nA NanoPower Voltage References |
Pages / Page | 23 / 2 — 3 GND. VOUT 2 |
File Format / Size | PDF / 1.3 Mb |
3 GND. VOUT 2
link to page 2 link to page 2 link to page 2 link to page 2 ISL21080 Pin Configuration Pin Descriptions 3 LD SOT-23 TOP VIEW PIN NUMBER PIN NAME DESCRIPTION 1 VIN Input Voltage Connection
V 1 IN
2 VOUT Voltage Reference Output
3 GND
3 GND Ground Connection
VOUT 2
Ordering Information PART PART NUMBER MARKING VOUT OPTION GRADE TEMP. RANGE TAPE AND REEL PACKAGE PKG. (Notes 2, 3) (Note 4) (V) (%) (°C) (UNITS) (Note 1) (RoHS Compliant) DWG. # ISL21080DIH309Z-TK BCLA 0.9 ±0.7 -40 to +85 1k 3 Ld SOT-23 P3.064A ISL21080DIH310Z-TK BCMA 1.024 ±0.7 -40 to +85 1k 3 Ld SOT-23 P3.064A ISL21080DIH312Z-TK BCNA 1.25 ±0.6 -40 to +85 1k 3 Ld SOT-23 P3.064A ISL21080CIH315Z-TK BCDA 1.5 ±0.5 -40 to +85 1k 3 Ld SOT-23 P3.064A ISL21080CIH315Z-T7A BCDA 1.5 ±0.5 -40 to +85 250 3 Ld SOT-23 P3.064A ISL21080CIH320Z-TK BCPA 2.048 ±0.3 -40 to +85 1k 3 Ld SOT-23 P3.064A ISL21080CIH325Z-TK BCRA 2.5 ±0.3 -40 to +85 1k 3 Ld SOT-23 P3.064A ISL21080CIH330Z-TK BCSA 3.0 ±0.2 -40 to +85 1k 3 Ld SOT-23 P3.064A ISL21080CIH333Z-TK BCTA 3.3 ±0.2 -40 to +85 1k 3 Ld SOT-23 P3.064A ISL21080CIH341Z-TK BCVA 4.096 ±0.2 -40 to +85 1k 3 Ld SOT-23 P3.064A ISL21080CIH350Z-TK BCWA 5.0 ±0.2 -40 to +85 1k 3 Ld SOT-23 P3.064A ISL2108009EV1Z ISL21080DIH309Z Evaluation Board ISL2108010EV1Z ISL21080DIH310Z Evaluation Board ISL2108012EV1Z ISL21080DIH312Z Evaluation Board ISL2108015EV1Z ISL21080DIH315Z Evaluation Board ISL2108020EV1Z ISL21080DIH320Z Evaluation Board ISL2108025EV1Z ISL21080DIH325Z Evaluation Board ISL2108030EV1Z ISL21080DIH330Z Evaluation Board ISL2108033EV1Z ISL21080DIH333Z Evaluation Board ISL2108040EV1Z ISL21080DIH341Z Evaluation Board ISL2108050EV1Z ISL21080DIH350Z Evaluation Board NOTES: 1. Refer to TB347 for details about reel specifications. 2. These Pb-free plastic packaged products employ special Pb-free material sets, molding compounds/die attach materials, and 100% matte tin plate plus anneal (e3 termination finish, which is RoHS compliant and compatible with both SnPb and Pb-free soldering operations). Pb-free products are MSL classified at Pb-free peak reflow temperatures that meet or exceed the Pb-free requirements of IPC/JEDEC J STD-020. 3. For Moisture Sensitivity Level (MSL), refer to the ISL21080DIH309, ISL21080DIH310, ISL21080DIH312, ISL21080CIH315, ISL21080CIH320, ISL21080CIH325, ISL21080CIH330, ISL21080CIH333, ISL21080CIH341, and ISL21080CIH350 product information pages. For more information about MSL, see TB363. 4. The part marking is located on the bottom of the part. FN6934 Rev.7.00 Page 2 of 23 Sep 28, 2018 Document Outline Applications Features Related Literature Pin Configuration Pin Descriptions Ordering Information Absolute Maximum Ratings Thermal Information Environmental Operating Conditions Recommended Operating Conditions Electrical Specifications (ISL21080-09, VOUT = 0.9V) Electrical Specifications (ISL21080-10, VOUT = 1.024V) Electrical Specifications (ISL21080-12, VOUT = 1.25V) Electrical Specifications (ISL21080-15, VOUT = 1.5V) Electrical Specifications (ISL21080-20, VOUT = 2.048V) Electrical Specifications (ISL21080-25, VOUT = 2.5V) Electrical Specifications (ISL21080-30, VOUT = 3.0V) Electrical Specifications (ISL21080-33, VOUT = 3.3V) Electrical Specifications (ISL21080-41 VOUT = 4.096V) Electrical Specifications (ISL21080-50 VOUT = 5.0V) Typical Performance Characteristics Curves VOUT = 0.9V Typical Performance Characteristics Curves VOUT = 1.5V Typical Performance Characteristics Curves High Current Application Applications Information FGA Technology Board Assembly Considerations Special Applications Considerations Nanopower Operation ISL21080 Used as a Low Cost Precision Current Source Output Impedance vs Load Current Board Mounting Considerations Noise Performance and Reduction Turn-On Time Temperature Coefficient Typical Application Circuits Revision History Package Outline Drawing
