23 /3 — link. to. page. 3. link. to. page. 3. link. to. page. 8. link. to. page. …
PDF / 1.3 Mb
link. to. page. 3. link. to. page. 3. link. to. page. 8. link. to. page. 8. link. to. page. 8. link. to. page. 8. link. to. page. 8. link. to. page. 3. link. to. page. 15. link. to. page. 8. link. to
link to page 3 link to page 3 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 3 link to page 15 link to page 8 link to page 8 ISL21080 Absolute Maximum Ratings Thermal Information Max Voltage Thermal Resistance (Typical) JA (°C/W) JC (°C/W) VIN to GND. -0.5V to +6.5V 3 Lead SOT-23 (Notes 6, 7). 275 110 VIN to GND (ISL21080-41 and 50 only) . -0.5V to +10V Maximum Junction Temperature . .+107°C VOUT to GND (10s) . -0.5V to VOUT +1V Continuous Power Dissipation (TA = +85°C) . .99mW VOUT to GND (10s) Storage Temperature Range. .-65°C to +150°C ISL21080-41 and 50 only . -0.5V to +5.1V Pb-Free Reflow Profile . see TB493 ESD Ratings Human Body Model (Tested to JESD22-A114) . 5kV Recommended Operating Conditions Machine Model (Tested to JESD22-A115). 500V Charged Device Model (Tested to JESD22-C101) . 2kV Temperature . -40°C to +85°C Latch-Up (Tested per JESD-78B; Class 2, Level A) . 100mA Supply Voltage . 2.7V to 5.5V Environmental Operating Conditions X-Ray Exposure (Note 5) . 10mRem CAUTION: Do not operate at or near the maximum ratings listed for extended periods of time. Exposure to such conditions may adversely impact product reliability and result in failures not covered by warranty. NOTES: 5. Measured with no filtering, distance of 10” from source, intensity set to 55kV and 70µA current, 30s duration. Other exposure levels should be analyzed for Output Voltage drift effects. See “Applications Information” on page 15. 6. JA is measured with the component mounted on a high-effective thermal conductivity test board in free air. See TB379 for details. 7. For JC, the “case temp” location is taken at the package top center. Electrical Specifications (ISL21080-09, VOUT = 0.9V) VIN = 3.0V, TA = -40°C to +85°C, IOUT = 0, unless otherwise specified. Boldface limits apply over the operating temperature range, -40°C to +85°C. MIN MAX PARAMETER SYMBOL CONDITIONS (Note 13) TYP (Note 13) UNIT Output Voltage VOUT 0.9 V VOUT Accuracy at TA = +25°C (Notes 8, 9) VOA -0.7 +0.7 % Output Voltage Temperature Coefficient TC VOUT 50 ppm/°C (Note 10) Input Voltage Range VIN 2.0 5.5 V Supply Current IIN 0.35 1.5 µA Line Regulation VOUT /VIN 2V ≤ VIN ≤ 5.5V 30 350 µV/V Load Regulation VOUT/IOUT Sourcing: 0mA ≤ IOUT ≤ 10mA 6 100 µV/mA Sinking: -10mA ≤ IOUT≤ 0mA 23 350 µV/mA Short-Circuit Current ISC TA = +25°C, VOUT tied to GND 30 mA Turn-On Settling Time tR VOUT = ±0.1% with no load 1 ms Ripple Rejection f = 120Hz -40 dB Output Voltage Noise eN 0.1Hz ≤ f ≤10Hz 40 µVP-P Broadband Voltage Noise VN 10Hz ≤ f ≤1kHz 10 µVRMS Noise Density f = 1kHz 1.1 µV/Hz Thermal Hysteresis (Note 11) VOUT/TA TA = +125°C 100 ppm Long Term Stability (Note 12) VOUT/t TA = +25°C 60 ppm FN6934 Rev.7.00 Page 3 of 23 Sep 28, 2018 Document Outline Applications Features Related Literature Pin Configuration Pin Descriptions Ordering Information Absolute Maximum Ratings Thermal Information Environmental Operating Conditions Recommended Operating Conditions Electrical Specifications (ISL21080-09, VOUT = 0.9V) Electrical Specifications (ISL21080-10, VOUT = 1.024V) Electrical Specifications (ISL21080-12, VOUT = 1.25V) Electrical Specifications (ISL21080-15, VOUT = 1.5V) Electrical Specifications (ISL21080-20, VOUT = 2.048V) Electrical Specifications (ISL21080-25, VOUT = 2.5V) Electrical Specifications (ISL21080-30, VOUT = 3.0V) Electrical Specifications (ISL21080-33, VOUT = 3.3V) Electrical Specifications (ISL21080-41 VOUT = 4.096V) Electrical Specifications (ISL21080-50 VOUT = 5.0V) Typical Performance Characteristics Curves VOUT = 0.9V Typical Performance Characteristics Curves VOUT = 1.5V Typical Performance Characteristics Curves High Current Application Applications Information FGA Technology Board Assembly Considerations Special Applications Considerations Nanopower Operation ISL21080 Used as a Low Cost Precision Current Source Output Impedance vs Load Current Board Mounting Considerations Noise Performance and Reduction Turn-On Time Temperature Coefficient Typical Application Circuits Revision History Package Outline Drawing
