Datasheet MAX6035 (Analog Devices) - 2
DescriptionHigh-Supply-Voltage, Precision Voltage Reference in SOT23
Pages / Page15 / 2 — High-Supply-Voltage, Precision Voltage Reference in SOT23. ABSOLUTE …
File Format / SizePDF / 795 Kb
High-Supply-Voltage, Precision Voltage Reference in SOT23. ABSOLUTE MAXIMUM RATINGS. MAX6035. Note 1:
High-Supply-Voltage, Precision Voltage Reference in SOT23 ABSOLUTE MAXIMUM RATINGS MAX6035 Note 1:
(Voltages referenced to GND) Operating Temperature Range: IN ..-0.3V to +36V MAX6035ESA ..-40°C to +85°C OUT ...-0.3V to (VIN + 0.3V) MAX6035_AUR ..-40°C to +125°C OUT Short-Circuit Duration to GND or IN (Note 1)...Continuous Storage Temperature Range ...-65°C to +150°C Current into Any Pin..±20mA Junction Temperature ..+150°C Continuous Power Dissipation Lead Temperature (soldering, 10s) ...+300°C 3-Pin SOT23 (derate 4.0mW/°C above +70°C)..320mW
MAX6035
8-Pin SO (derate 5.9mW/°C above +70°C)...470.6mW
Note 1:
Continuous power dissipation should also be observed. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
ELECTRICAL CHARACTERISTICS—MAX6035_AUR25 and MAX6035ESA25 (2.5V)
(VIN = 5V, IOUT = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 2)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX6035AAUR, 2.4950 2.5000 2.5050 Output Voltage V MAX6035ESA (0.2%) OUT TA = +25°C V MAX6035BAUR 2.4875 2.5000 2.5125 MAX6035AAUR 20 TA = 0°C to +70°C MAX6035BAUR 50 MAX6035AAUR 25 Output Voltage Temperature Coefficient TCVOUT TA = -40°C to +85°C MAX6035ESA 40 ppm/°C (Notes 3 and 6) MAX6035BAUR 65 MAX6035AAUR 30 TA = -40°C to +125°C MAX6035BAUR 75 TA = +25°C 4 15 Line Regulation (Note 4) ∆VOUT/∆VIN (VOUT + 2V) ≤ VIN ≤ 33V µV/V TA = TMIN to TMAX 20 Sourcing: 25 70 T 0 A = +25°C, ≤ IOUT ≤ 10mA MAX6035_AUR Sinking: 45 180 -2mA ≤ IOUT ≤ 0 Sourcing: 85 T 0 A = TMIN to TMAX, ≤ IOUT ≤ 10mA MAX6035_AUR Sinking: 225 -2mA ∆VOUT/ ≤ IOUT ≤ 0 Load Regulation (Note 4) ∆ µV/mA IOUT Sourcing: 105 175 T 0 A = +25°C, ≤ IOUT ≤ 10mA MAX6035ESA Sinking: 205 375 -2mA ≤ IOUT ≤ 0 Sourcing: 350 0 T ≤ IOUT ≤ 10mA A = TMIN to TMAX, MAX6035ESA Sinking: 500 -2mA ≤ IOUT ≤ 0 Short to GND 27 OUT Short-Circuit Current ISC mA Short to IN -4
2 _______________________________________________________________________________________
