Datasheet MAX6035 (Analog Devices) - 6
Description | High-Supply-Voltage, Precision Voltage Reference in SOT23 |
Pages / Page | 15 / 6 — High-Supply-Voltage, Precision Voltage Reference in SOT23. Typical … |
File Format / Size | PDF / 795 Kb |
High-Supply-Voltage, Precision Voltage Reference in SOT23. Typical Operating Characteristics. MAX6035AAUR25. MAX6035AAUR30
High-Supply-Voltage, Precision Voltage Reference in SOT23 Typical Operating Characteristics
(VIN = 5V for MAX6035AAUR25/MAX6035AAUR30, VIN = 15V for MAX6035AAUR50, IOUT = 0, TA = +25°C, unless otherwise noted.)
MAX6035AAUR25 MAX6035AAUR30 MAX6035AAUR50 OUTPUT VOLTAGE TEMPERATURE DRIFT OUTPUT VOLTAGE TEMPERATURE DRIFT OUTPUT VOLTAGE TEMPERATURE DRIFT
2.5035 3.003 5.005 THREE TYPICAL PARTS THREE TYPICAL PARTS THREE TYPICAL PARTS 2.5030 5.004 MAX6035 toc03 MAX6035 toc01 MAX6035 toc02 3.001 2.5025 5.003
MAX6035
2.5020 5.002 2.999 2.5015 5.001 2.5010 2.997 5.000 OUTPUT VOLTAGE (V) 2.5005 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) 4.999 2.5000 2.995 4.998 2.4995 4.997 2.4990 2.993 -40 -15 10 35 60 85 110 -40 -15 10 35 60 85 110 -40 -15 10 35 60 85 110 TEMPERATURE (°C) TEMPERATURE ( TEMPERATURE ( °C) °C)
MAX6035 MAX6035 MAX6035 LINE REGULATION (VOUT = 2.5V) LINE REGULATION (V LINE REGULATION (V OUT = 3V) OUT = 5V)
2.5010 3.0005 4.9995 TA = +125°C TA = +125°C 3.0000 2.5005 TA = +125°C MAX6035 toc06 MAX6035 toc04 MAX6035 toc05 TA = +85°C 4.9990 2.9995 2.5000 T T A = +85°C A = +85°C 2.9990 2.4995 TA = +25°C 4.9985 2.9985 2.4990 TA = +25°C 2.9980 4.9980 2.4985 TA = +25°C OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) 2.9975 OUTPUT VOLTAGE (V) TA = -40 T °C A = -40 2.4980 °C 2.9970 4.9975 2.4975 2.9965 TA = -40°C 2.4970 2.9960 4.9970 4 10 16 22 28 34 4 10 16 22 28 34 6 10 14 18 22 26 30 34 INPUT VOLTAGE (V) INPUT VOLTAGE (V) INPUT VOLTAGE (V)
MAX6035 MAX6035 MAX6035 LOAD REGULATION (V LOAD REGULATION (V LOAD REGULATION (VOUT = 5V) OUT = 2.5V) OUT = 3V)
2.5010 3.0005 5.001 TA = +125°C TA = +125 2.5005 3.0000 °C 5.000 TA = +85°C MAX6035 toc09 MAX6035 toc07 MAX6035 toc08 TA = +125°C 2.9995 2.5000 TA = +85°C 4.999 2.9990 2.4995 2.9985 4.998 2.4990 TA = +85°C 2.9980 2.4985 4.997 2.9975 TA = +25°C OUTPUT VOLTAGE (V) 2.4980 TA = +25°C OUTPUT VOLTAGE (V) TA = +25°C OUTPUT VOLTAGE (V) 2.9970 4.996 2.4975 2.9965 4.995 2.4970 2.9960 T T T A = -40°C A = -40°C A = -40°C 2.4965 2.9955 4.994 -2 0 2 4 6 8 10 -2 0 2 4 6 8 10 -2 0 2 4 6 8 10 LOAD CURRENT (mA) LOAD CURRENT (mA) LOAD CURRENT (mA)
6 _______________________________________________________________________________________
