Datasheet MAX6035 (Analog Devices) - 7
Description | High-Supply-Voltage, Precision Voltage Reference in SOT23 |
Pages / Page | 15 / 7 — High-Supply-Voltage, Precision. Voltage Reference in SOT23. MAX6035. … |
File Format / Size | PDF / 795 Kb |
High-Supply-Voltage, Precision. Voltage Reference in SOT23. MAX6035. Typical Operating Characteristics (continued)
High-Supply-Voltage, Precision Voltage Reference in SOT23 MAX6035 Typical Operating Characteristics (continued)
(VIN = 5V for MAX6035AAUR25/MAX6035AAUR30, VIN = 15V for MAX6035AAUR50, IOUT = 0, TA = +25°C, unless otherwise noted.)
MAX6035 MAX6035 MAX6035 POWER-SUPPLY REJECTION RATIO POWER-SUPPLY REJECTION RATIO POWER-SUPPLY REJECTION RATIO vs. FREQUENCY (VOUT = 2.5V) vs. FREQUENCY (VOUT = 3V) vs. FREQUENCY (VOUT = 5V)
0 0 0 -20 MAX6035 toc10 -20 -20 MAX6035 toc11 MAX6035 toc12 -40 -40 -40 -60 -60 -60 PSRR (dB) PSRR (dB) PSRR (dB) -80 -80 -80 -100 -100 -100 -120 -120 -120 0.001 0.1 10 1000 0.001 0.1 10 1000 0.001 0.1 10 1000 FREQUENCY (kHz) FREQUENCY (kHz) FREQUENCY (kHz)
MAX6035 MAX6035 MAX6035 SUPPLY CURRENT SUPPLY CURRENT SUPPLY CURRENT vs. INPUT VOLTAGE (VOUT = 2.5V) vs. INPUT VOLTAGE (VOUT = 3V) vs. INPUT VOLTAGE (VOUT = 5V)
95 95 95 90 TA = -40°C MAX6035 toc13 MAX6035 toc14 90 MAX6035 toc15 90 µA) µA) T T A = -40°C 85 A = +25°C µA) TA = -40°C 85 TA = +25°C 85 TA = +25°C 80 80 80 T 75 A = +125°C SUPPLY CURRENT ( SUPPLY CURRENT ( SUPPLY CURRENT ( 75 TA = +125°C 75 70 TA = +125°C 65 70 70 4 10 16 22 28 34 4 10 16 22 28 34 6 12 18 24 30 INPUT VOLTAGE (V) INPUT VOLTAGE (V) INPUT VOLTAGE (V)
MAX6035 MAX6035 MAX6035 OUTPUT IMPEDANCE OUTPUT IMPEDANCE OUTPUT IMPEDANCE vs. FREQUENCY (VOUT = 2.5V) vs. FREQUENCY (VOUT = 3V) vs. FREQUENCY (VOUT = 5V)
400 400 300 250 MAX6035 toc16 MAX6035 toc17 MAX6035 toc18 ) Ω 300 Ω 300 Ω 200 200 200 150 100 OUTPUT IMPEDANCE ( OUTPUT IMPEDANCE ( OUTPUT IMPEDANCE ( 100 100 50 0 0 0 0.01 0.1 1 10 100 1000 0.001 0.1 10 1000 0.01 0.1 1 10 100 1000 FREQUENCY (kHz) FREQUENCY (kHz) FREQUENCY (kHz)
_______________________________________________________________________________________ 7
