Datasheet MAX6035 (Analog Devices) - 8
Description | High-Supply-Voltage, Precision Voltage Reference in SOT23 |
Pages / Page | 15 / 8 — High-Supply-Voltage, Precision Voltage Reference in SOT23. Typical … |
File Format / Size | PDF / 795 Kb |
High-Supply-Voltage, Precision Voltage Reference in SOT23. Typical Operating Characteristics (continued). MAX6035
High-Supply-Voltage, Precision Voltage Reference in SOT23 Typical Operating Characteristics (continued)
(VIN = 5V for MAX6035AAUR25/MAX6035AAUR30, VIN = 15V for MAX6035AAUR50, IOUT = 0, TA = +25°C, unless otherwise noted.)
MAX6035 MAX6035 MAX6035 0.1Hz to 10Hz OUTPUT NOISE 0.1Hz to 10Hz OUTPUT NOISE 0.1Hz to 10Hz OUTPUT NOISE (VOUT = 2.5V) (VOUT = 3V) (VOUT = 5V)
MAX6035 toc19 MAX6035 toc20 MAX6035 toc21
MAX6035
10µV/div 10µV/div 20µV/div 1s/div 1s/div 1s/div
MAX6035 MAX6035 MAX6035 10Hz to 1kHz OUTPUT NOISE 10Hz to 1kHz OUTPUT NOISE 10Hz to 1kHz OUTPUT NOISE (VOUT = 2.5V) (VOUT = 3V) (VOUT = 5V)
MAX6035 toc22 MAX6035 toc23 MAX6035 toc24 50µV/div 50µV/div 100µV/div 100ms/div 100ms/div 100ms/div
MAX6035 MAX6035 MAX6035 TURN-ON TRANSIENT (VOUT = 2.5V) TURN-ON TRANSIENT (VOUT = 3V) TURN-ON TRANSIENT (VOUT = 5V)
MAX6035 toc25 MAX6035 toc26 MAX6035 toc27 CL = 50pF CL = 50pF CL = 50pF VIN VIN VIN 5V/div 5V/div 10V/div 0V 0V VOUT VOUT VOUT 1V/div 1V/div 2V/div 0V 0V 10µs/div 10µs/div 40µs/div
8 _______________________________________________________________________________________
