PART NUMBER SSL-LXA228SRC-TR31 REV H PROFILECARRIER TAPE DIMENSION TAPE FEED DIRECTION 2 ±0.1 4 ±0.1 1.50 ±0.10 0.36 ±0.10 ABOVE 255 C 260 C MAX. 30S MAX. 10S MAX. 1.75 ±0.10 A 3 C/S MAX. CATHODE 6 C/S MAX. 5.5 ±0.1 TEMPERATURE PRE-HEATING 150~200 C ABOVE 217 C 12.00 ±0.30 60~120 SEC. 60~150 SEC. ANODE A 4.0 ±0.1 PUSH PIN 3.15 ±0.1 TIME THROUGH HOLE SECTION A-A NOTE:1. 1,000 PCS PER REEL. *UNLESS OTHERWISE SPECIFIED TOLERANCES PER DECIMAL PRECISION ARE: X= + ±1 (±0.039), X.X=±0.5 (±0.020), X.XX=±0.25 (±0.010), X.XXX=±0.127 (±0.005). LEAD SIZE=±0.05 (±0.002), LEAD LENGTH=±0.75 (±0.030). MIN= MAX.= +DECIMAL PRECISION 0.00 -0.00 -DECIMAL PRECISION 425 N. GARY AVE. 2(L)*5.8(W)*2.7(H)mm, AXIAL LED, AlGaInP 575nm GREEN, WATER CLEAR LENS, TAPE & REEL. DATE: 2022.09.20 DRAWN BY:C.C. CAROL STREAM, IL 60188 PAGE: 2 OF 2 CHKD BY: G.Y. PHONE:800-278-5666 **THE SPECIFICATIONS MAY CHANGE AT ANY TIME WITHOUT NOTICE.** FAX:630-315-2150 CONFIDENTIAL INFORMATION SCALE : THE INFORMATION CONTAINED IN THIS DOCUMENT IS THE PROPERTY OF LUMEX INC. EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY LUMEX INC., THE HOLDER OF THIS DOCUMENT SHALL NTF APRVD BY: E.C. WEB:WWW.LUMEX.COM KEEP ALL INFORMATION CONTAINED HEREIN CONFIDENTIAL AND SHALL PROTECT SAME IN WHOLE OR IN PART FROM DISCLOSURE AND DISSEMINATION TO ALL THIRD PARTIES. UNIT: mm [INCH] Pb
