Low-Cost, Micropower, Precision, 3-Terminal, 1.2V Voltage ReferenceABSOLUTE MAXIMUM RATINGS Supply Voltage (VIN) ..-0.3V to +12V Operating Temperature Range ...-40°C to +85°C VOUT ..-0.3V to (VIN + 0.3V) Storage Temperature Range ...-65°C to +160°C Output Short-Circuit Duration ..Continuous to Either Supply Lead Temperature (soldering, 10sec) ...+300°C Continuous Power Dissipation (TA = +70°C) SOT23 (derate 4mW/°C above +70°C) ...320mW Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to MAX6120 absolute maximum rating conditions for extended periods may affect device reliability. DC ELECTRICAL CHARACTERISTICS (VIN = 2.4V, ILOAD = 0mA, TA = +25°C, unless otherwise noted.) PARAMETERSYMBOLCONDITIONSMINTYPMAXUNITS TA = +25°C 1.188 1.200 1.212 V Output Voltage VOUT MAX6120EUR (SOT23) TA = TMIN to TMAX (Note 2) 1.176 1.224 V Output Voltage Temperature TCVOUT MAX6120EUR (SOT23), TA = TMIN to TMAX (Note 2) 30 100 ppm/°C Coefficient 0.1Hz to 10Hz 10 Output Voltage Noise en µVp-p 10Hz to 10kHz 400 Line Regulation VOUT/VIN VIN = 2.4V to 11V, TA = TMIN to TMAX (Note 1) 2 30 µV/V Load Regulation VOUT/IOUT ILOAD = -50µA to 400µA (Note 1) 0.1 1 µV/µA TA = +25°C 50 58 Quiescent Supply Current IQ µA TA = TMIN to TMAX (Note 1) 70 Change in Supply Current IQ/VIN VIN = 2.4V to 11V 1.5 5 µA/V vs. Input Voltage VOUT shorted to GND 4.3 mA Short-Circuit Output Current ISC VOUT shorted to VIN 400 µA Note 1: Production testing done at TA = +25°C, over temperature limits guaranteed by parametric correlation data. Note 2: Contact factory for availability of a higher-grade, lower-TC option in a SOT23 package. __________________________________________Typical Operating Characteristics (VIN = 3V, ILOAD = 0mA, TA = +25°C, unless otherwise noted.) SUPPLY CURRENTOUTPUT VOLTAGESUPPLY CURRENTvs. INPUT VOLTAGEvs. INPUT VOLTAGEvs. TEMPERATURE 80 1.20010 75 MAX6120-02 MAX6120 TOC-01 MAX6120 TOC-02 70 µA) 1.20005 µA) 70 VIN = 9V 65 1.20000 60 VIN = 5V 60 V SUPPLY CURRENT ( OUTPUT VOLTAGE (V) SUPPLY CURRENT ( IN = 3V 1.19995 55 50 1.19990 50 2 3 4 5 6 7 8 9 10 11 2 3 4 5 6 7 8 9 10 11 -50 -25 0 25 50 75 100 INPUT VOLTAGE (V) INPUT VOLTAGE (V) TEMPERATURE (°C) 2_______________________________________________________________________________________
