Datasheet MAX6078A, MAX6078B (Analog Devices) - 7
DescriptionLow-Power, Low-Drift, Low-Noise Voltage Reference
Pages / Page18 / 7 — Electrical Characteristics – 3.0V (continued). PARAMETER. SYMBOL. …
File Format / SizePDF / 3.2 Mb
Electrical Characteristics – 3.0V (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. Electrical Characteristics – 3.3V
Electrical Characteristics – 3.0V (continued) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS Electrical Characteristics – 3.3V
link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 MAX6078A/MAX6078B Low-Power, Low-Drift, Low-Noise Voltage Reference
(VIN = +5V, IOUT = 0mA, COUT = 0.1µF, TA = -55°C to +125°C, unless otherwise specified. Typical values are at TA = +25°C (Note 1))
Capacitive-Load 0.1 4.7 µF Stability Range Supply Voltage VIN 3.2 5.5 V TA = +25°C 10 15 Quiescent Supply I TA = -55°C to +85°C 16.5 μA Current IN TA = -55°C to +125°C 18 Shutdown Supply I Current SD 0.1 2 µA Enable Input Current IEN 0.1 µA Enable Logic-High VIH 0.7 x VIN V Enable Logic-Low VIL 0.3 x VIN V
Output Voltage T Accuracy A = +25°C -0.04 +0.04 % Output Voltage -40°C to +125°C (Note 2) 2 10 TCV ppm/°C Temperature Drift OUT -55°C to +125°C (Note 2) 2 10 Over specified operating input voltage Line Regulation 10 175 µV/V range Load Regulation -3mA ≤ IOUT ≤ +3mA 5 125 µV/mA I Dropout Voltage OUT = 3mA (Note 3) 100 mV IOUT = 100µA (Note 3) 10 Output Current IOUT Guaranteed by load regulation -3 +3 mA Sourcing to ground 36 Short-Circuit Current ISC mA Sinking current from VIN 24 0 to 4000hrs 16 0 to 1000hrs 9.8 Long-Term Stability TA = +35°C 1000hrs to 2000hrs 2.5 ppm 2000hrs to 3000hrs 1.89 3000hrs to 4000hrs 1.96 Thermal Hysteresis (Note 4) 20 ppm 0.1Hz to 10Hz, COUT = 0.1µF 12 µVP-P 10Hz to 10kHz, C Output Noise Voltage e OUT = 0.1μF 30 OUT µV 10Hz to 10kHz, C RMS OUT = 0.1μF, CNR = 20 0.01µF Output Noise Spectral f = 100Hz, COUT = 0.1µF 580 nV/√Hz Density f = 100Hz, COUT = 0.1μF, CNR = 0.01μF 385 Ripple Rejection f = 60Hz 50 dB www.analog.com Analog Devices | 7 Document Outline General Description Applications Benefits and Features Simplified Block Diagram Absolute Maximum Ratings Package Information 8 TDFN 8 WLP Electrical Characteristics – 2.5V Electrical Characteristics – 2.5V (continued) Electrical Characteristics – 3.0V Electrical Characteristics – 3.0V (continued) Electrical Characteristics – 3.3V Electrical Characteristics – 3.3V (continued) Electrical Characteristics – 5.0V Electrical Characteristics – 5.0V (continued) Typical Operating Characteristics Typical Operating Characteristics (continued) Pin Configurations 6 WLP 8 TDFN-EP Pin Description Pin Description (continued) Typical Operating Circuit Detailed Description Wideband Noise Reduction (NR) Output Bypassing Turn-On Time Output Force and Sense Shutdown Thermal Hysteresis Applications Information Precision Current Source Ordering Information Revision History
