Datasheet MAX6125, MAX6141, MAX6145, MAX6150, MAX6160 (Analog Devices) - 6
DescriptionSOT23, Low-Cost, Low-Dropout, 3-Terminal Voltage References
Pages / Page12 / 6 — Typical Operating Characteristics (continued). MAX6141/MAX6145/MAX6150. …
Typical Operating Characteristics (continued). MAX6141/MAX6145/MAX6150. MAX6160. DROPOUT VOLTAGE vs. TEMPERATURE
Typical Operating Characteristics (continued) MAX6141/MAX6145/MAX6150 MAX6160 DROPOUT VOLTAGE vs TEMPERATURE
MAX6125/MAX6141/ SOT23, Low-Cost, Low-Dropout, MAX6145/MAX6150/MAX6160 3-Terminal Voltage References
(VIN = VIN(MIN), IOUT = 0mA, TA = +25°C, unless otherwise noted.)
MAX6141/MAX6145/MAX6150 MAX6160 DROPOUT VOLTAGE vs. TEMPERATURE ADJ INPUT CURRENT vs. TEMPERATURE
100 120 12 I toc V OUT = 1mA IN = 2.7V VADJ = 1.23V MAX6125 toc11 MAX6125 100 96 80 92 60 88 40 DROPOUT VOLTAGE (mV) ADJ INPUT CURRENT (nA) 84 20 80 0 -50 -25 0 25 50 75 100 -50 -25 0 25 50 75 100 TEMPERATURE (°C) TEMPERATURE (°C)
CHANGE IN OUTPUT VOLTAGE CHANGE IN OUTPUT VOLTAGE vs. INPUT VOLTAGE vs. TEMPERATURE
1.0 0.2 VALID OVER VIN(MIN) TO VIN(MAX) FOR EACH PART MAX6125 toc13 * (%) MAX6125 toc14 0.1 0.5 0 0 -0.1 -0.5 -0.2 CHANGE IN OUTPUT VOLTAGE CHANGE IN OUTPUT VOLTAGE** (%) -1.0 -0.3 2 4 6 8 10 12 14 -50 -25 0 25 50 75 100 INPUT VOLTAGE (V) TEMPERATURE (°C) *With respect to output voltage at VIN = VIN(MIN). **With respect to output voltage at TA = +25°C.
POWER-SUPPLY REJECTION RATIO MAX6141ESA THERMAL HYSTERESIS vs. FREQUENCY (5 PARTS, 6 TEMPERATURE CYCLES)
140 200 VIN = 4.3V, VOUT = 4.096V, 160 C 120 OUT = NO LOAD MAX6125 toc15 120 IC4 100 (ppm) 80 IC2 80 40 0 PSRR (dB) 60 HYSTERESIS -40 40 -80 IC5 IC3 THERMAL -120 20 -160 IC1 0 -200 0.0001 0.001 0.01 0.1 1 10 1 2 3 4 5 6 FREQUENCY (kHz) TEMPERATURE CYCLES www.maximintegrated.com Maxim Integrated │ 6
