Datasheet ADRF5030 (Analog Devices) - 3
Description100 MHz to 20 GHz, Non-Reflective, Silicon SPDT Switch
Pages / Page13 / 3 — ADRF5030. SPECIFICATIONS. Table 1. Electrical Characteristics. Parameter. …
File Format / SizePDF / 752 Kb
ADRF5030. SPECIFICATIONS. Table 1. Electrical Characteristics. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max. Unit. analog.com
ADRF5030 SPECIFICATIONS Table 1 Electrical Characteristics Parameter Symbol Test Conditions/Comments Min Typ Max Unit analog.com
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 Data Sheet
VDD = 3.3 V, VSS = −3.3, VCTRL = 0 V or VDD, TCASE = 25°C, 50 Ω system, unless otherwise noted. RFx refers to RF1 or RF2.
Table 1. Electrical Characteristics Parameter Symbol Test Conditions/Comments Min Typ Max Unit
FREQUENCY RANGE f 0.1 20 GHz INSERTION LOSS Between RFC and RFx (On) 0.1 GHz to 6 GHz 0.7 dB 6 GHz to 12 GHz 0.9 dB 12 GHz to 20 GHz 1.2 dB RETURN LOSS RFC 0.1 GHz to 20 GHz 21 dB RFx (On) 0.1 GHz to 20 GHz 19 dB RFx (Off) 0.1 GHz to 20 GHz 17 dB ISOLATION Between RFC to RFx and RFx to RFx 0.1 GHz to 6 GHz 55 dB 6 GHz to 12 GHz 50 12 GHz to 20 GHz 45 dB SWITCHING CHARACTERISTICS Rise and Fall Time tRISE, tFALL 10% to 90% of RF output 13 ns On and Off Time tON, tOFF 50% VCTRL to 90% of RF output 70 ns Settling Time (0.1 dB) 50% VCTRL to 0.1 dB of final RF output 95 ns INPUT LINEARITY1 f = 0.1 GHz to 20 GHz Input Compression P0.1dB 36 dBm Third-Order Intercept IP3 Two-tone input power = 14 dBm each tone, f = 0.1 GHz 60 dBm to 20 GHz, Δf = 1 MHz Second-Order Intercept IP2 Two-tone input power = 14 dBm each tone, f = 8 GHz. 110 dBm Δf = 1 MHz VIDEO FEEDTHROUGH 45 mVp-p SUPPLY CURRENT VDD and VSS pins Positive Supply Current IDD 150 µA Negative Supply Current ISS 520 µA DIGITAL CONTROL INPUTS CTRL, EN pins Voltage Low VINL 0 0.8 V High VINH 1.2 3.3 V Current Low IINL <1 µA High IINH 33 µA RECOMMENDED OPERATING CONDITIONS Supply Voltage Positive VDD 3.15 3.45 V Negative VSS −3.45 −3.15 V Digital Control Inputs Voltage VCTRL 0 VDD V RF Input Power2, 3 PIN f = 0.1 GHz to 20 GHz, TCASE = 85°C Through Path RF signal is applied to RFC or through connected RFx Average (RF1/RF2). 33 dBm Peak, Pulse4, 5 36 dBm Terminated Path RF signal is applied to unselected RFx (terminated Average within internal resistor). 33 dBm Peak, Pulse 36 dBm
analog.com Rev. 0 | 3 of 13
Document Outline Features Applications Functional Block Diagram General Description Specifications Single-Supply Operation Absolute Maximum Ratings Thermal Resistance Power Derating Curves Electrostatic Discharge (ESD) Ratings ESD Ratings for the ADRF5030 ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Insertion Loss, Return Loss, and Isolation Input Power Compression and Third-Order Intercept Theory of Operation RF Input and Output Power Supply Applications Information Recommendations for Printed Circuit Board Design Outline Dimensions Ordering Guide Notes
