Datasheet ADRF5030 (Analog Devices) - 4
Description100 MHz to 20 GHz, Non-Reflective, Silicon SPDT Switch
Pages / Page13 / 4 — ADRF5030. SPECIFICATIONS. Table 1. Electrical Characteristics …
File Format / SizePDF / 752 Kb
ADRF5030. SPECIFICATIONS. Table 1. Electrical Characteristics (Continued). Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max
ADRF5030 SPECIFICATIONS Table 1 Electrical Characteristics (Continued) Parameter Symbol Test Conditions/Comments Min Typ Max
link to page 10 link to page 10 link to page 5 Data Sheet
ADRF5030 SPECIFICATIONS Table 1. Electrical Characteristics (Continued) Parameter Symbol Test Conditions/Comments Min Typ Max Unit
Hot Switching RF signal is applied to RFC or RFx while switching in Average between RF1/RF2. 33 dBm Peak, Pulse 36 dBm Case Temperature TCASE −40 +105 °C 1 For input linearity performance over frequency, see Figure 12 to Figure 15. 2 For power derating over frequency, see the Power Derating Curves section. 3 For 105°C operation, the power handling degrades from the TCASE = 85°C specification by 3 dB. 4 Peak: ( ≤100 ns pulse duration, 5% duty cycle). 5 Pulse: (>100 ns pulse duration, 15% duty cycle).
SINGLE-SUPPLY OPERATION
VDD = 3.3 V, VSS = 0, VCTRL = 0 V or VDD, TCASE = 25°C for 50 Ω system, unless otherwise noted.
Table 2. Single-Supply Operational Specifications Parameter Symbol Test Conditions/Comments Min Typ Max Unit
FREQUENCY RANGE f 0.1 20 GHz SWITCHING CHARACTERISTICS Rise and Fall Time tRISE, tFALL 10% to 90% of RF output 110 ns On and Off Time tON, tOFF 50% VCTRL to 90% of RF output 230 ns Settling Time (0.1 dB) 50% VCTRL to 0.1 dB of final RF output 250 ns INPUT LINEARITY f = 0.1 GHz to 20 GHz Input Compression P0.1dB 22 dBm Third-Order Intercept IP3 Two-tone input power = 6 dBm each tone, f = 0.1 52 dBm GHz to 20 GHz, Δf = 1 MHz RECOMMENDED OPERATING CONDITONS RF Input Power PIN f = 0.1 GHz to 20 GHz, TCASE = 85°C Through Path RF signal is applied to RFC or through connected 22 dBm to RFx. Terminated Path RF signal is applied to unselected RFx (terminated 22 dBm within internal resistor). Hot Switching RF signal is applied to RFC or RFx while switching 22 dBm in between RF1/RF2.
analog.com Rev. 0 | 4 of 13
Document Outline Features Applications Functional Block Diagram General Description Specifications Single-Supply Operation Absolute Maximum Ratings Thermal Resistance Power Derating Curves Electrostatic Discharge (ESD) Ratings ESD Ratings for the ADRF5030 ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Insertion Loss, Return Loss, and Isolation Input Power Compression and Third-Order Intercept Theory of Operation RF Input and Output Power Supply Applications Information Recommendations for Printed Circuit Board Design Outline Dimensions Ordering Guide Notes
