Datasheet MAX6043 (Analog Devices)
Description | Precision High-Voltage Reference in SOT23 |
Pages / Page | 16 / 1 — Design. Tools. Support. Resources. and Models. here. Precision … |
File Format / Size | PDF / 2.5 Mb |
Design. Tools. Support. Resources. and Models. here. Precision High-Voltage Reference in SOT23. MAX6043. General Description. Features
Design Tools Support Resources and Models
Click
here
to ask an associate for production status of specific part numbers.
Precision High-Voltage Reference in SOT23 MAX6043 General Description Features
The MAX6043 precision voltage reference provides ● +2.5V, +3.3V, +4.096V, +5.0V, or +10V Output accurate preset +2.5V, +3.3V, +4.096V, +5.0V, and +10V Voltages reference voltages from up to +40V input voltages. The ● Excellent Temperature Stability: 15ppm/°C (max) MAX6043 features a proprietary temperature coefficient curvature-correction circuit and laser-trimmed thin-film ● Tight Initial Accuracy: 0.05% (max) resistors that result in a very low temperature coefficient ● Tiny SOT23 Package of 15ppm/°C (max) and excellent initial accuracy of 0.05% ● Wide +4.5V to +40V Supply Voltage Range (max). Low temperature drift and low noise make the ● Low Noise: 4μV MAX6043 ideal for use with high-resolution A/D or D/A P-P (typ at 2.5V Output) converters. ● Short-Circuit Protected The MAX6043 draws 320μA of supply current and sourc- ● Wide Operating Temperature Range es 10mA or sinks 0.6mA of load current. The MAX6043 -40°C to +125°C uses bandgap technology for low-noise performance ● Stable with Capacitive Loads from 0 to 100μF and excellent accuracy. The MAX6043 does not require ● No External Capacitors Required for Stability an output bypass capacitor for stability, and is stable with capacitive loads up to 100μF. Eliminating the output
Pin Configuration
bypass capacitor saves valuable board area in space- critical applications. The supply-independent, low supply TOP VIEW current makes the MAX6043 ideal for battery-operated, high-performance systems. I.C.* 1 6 OUTS The MAX6043 is available in a 6-pin SOT23 package and operates over the automotive (-40°C to +125°C) GND 2
MAX6043
5 OUTF temperature range.
Applications
I.C.* 3 4 IN ● Analog-to-Digital Converters ● Digital-to-Analog Converters
SOT23
● Digital Voltmeters *INTERNALLY CONNECTED. DO NOT CONNECT. ● Voltage Regulators ● Threshold Detectors
Ordering Information PART OUTPUT VOLTAGE TEMPCO INITIAL ACCURACY (V) (PPM/°C) (%) TOP MARK
MAX6043BAUT25-T 2.500 20 0.10 ABDQ MAX6043CAUT25-T 2.500 65 0.50 ABDR MAX6043BAUT33-T 3.300 20 0.10 ABDS MAX6043BAUT41-T 4.096 20 0.10 ABDU #Denotes an RoHS-compliant device that may include lead that is exempt under the RoHS requirements. T = Tape and reel.
Ordering Information continued at end of data sheet. Typical Operating Circuit appears at end of data sheet.
19-3036; Rev 7; 11/21 © 2021 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. One Analog Way, Wilmington, MA 01887 U.S.A. | Tel: 781.329.4700 | © 2021 Analog Devices, Inc. All rights reserved.
