Datasheet MAX6043 (Analog Devices) - 5
DescriptionPrecision High-Voltage Reference in SOT23
Pages / Page16 / 5 — MAX6043. Electrical Characteristics—VOUT = +4.096V. PARAMETER. …
File Format / SizePDF / 2.5 Mb
MAX6043. Electrical Characteristics—VOUT = +4.096V. PARAMETER. CONDITIONS. MIN. TYP. MAX. UNITS. OUTPUT. DYNAMIC CHARACTERISTICS. INPUT
MAX6043 Electrical Characteristics—VOUT = +4.096V PARAMETER CONDITIONS MIN TYP MAX UNITS OUTPUT DYNAMIC CHARACTERISTICS INPUT
MAX6043
(VIN = +10V, IOUT = 0, TA = TMIN to TMAX. Typical values are at TA = +25°C, unless otherwise noted.) (Note 1)
MAX6043B (0.1%) 4.0919 4.0960 4.1001 Output Voltage IOUT = 0, TA = +25°C V MAX6043C (0.5%) 4.0755 4.0960 4.1165 Output-Voltage Temperature MAX6043B_41 5 25 Coefficient (Note 2) TA = -40°C to +125°C ppm/°C MAX6043C_41 10 65 T Line Regulation (Note 4) 6.1V ≤ V A = +25°C 1 6 IN ≤ 40V ppm/V TA = -40°C to +125°C 1.5 10 Sourcing, TA = +25°C 19 70 0 ≤ IOUT ≤ 10mA T Load Regulation (Note 4) A = -40°C to +125°C 70 ppm/mA Sinking, TA = +25°C 100 900 -0.6mA ≤ IOUT ≤ 0mA TA = -40°C to +125°C 900 OUT shorted to GND 60 OUT Short-Circuit Current mA OUT shorted to IN -2 Thermal Hysteresis (Note 3) 150 ppm Long-Term Stability Δt = 1000hr 150 ppm
0.1Hz to 10Hz 6.6 µV Output Noise Voltage P-P 10Hz to 1kHz 12 µVRMS Turn-On Settling Time To VOUT = 0.05% of final value, COUT = 50pF 200 µs
INPUT
Supply Voltage Range Inferred from line regulation test 6.1 40.0 V T Quiescent Supply Current I A = +25°C 320 490 OUT = 0 µA TA = -40°C to +125°C 380 650 www.analog.com Analog Devices │ 5
