Datasheet MAX6225, MAX6241, MAX6250 (Analog Devices) - 2
DescriptionLow-Noise, Precision, +2.5V/+4.096V/+5V Voltage References
Pages / Page11 / 2 — Absolute Maximum Ratings. Electrical Characteristics—MAX6225. PARAMETER. …
Absolute Maximum Ratings. Electrical Characteristics—MAX6225. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS
Absolute Maximum Ratings Electrical Characteristics—MAX6225 PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX6225/MAX6241/MAX6250 Low-Noise, Precision, +2.5V/+4.096V/+5V Voltage References
(Voltages Referenced to GND) 8-Pin CERDIP (derate 8.00mW/°C above +70°C)...640mW IN..-0.3V to +40V Operating Temperature Ranges OUT, TRIM ..-0.3V to +12V MAX62_ _ _C_ A...0°C to +70°C NR ..-0.3V to +6V MAX62_ _ _E_ A..-40°C to +85°C OUT Short-Circuit to GND Duration (VIN ≤ 12V)..Continuous MAX62_ _ _MJA..-55°C to +125°C OUT Short-Circuit to GND Duration (VIN ≤ 40V) ..5s Storage Temperature Range ..-65°C to +150°C OUT Short-Circuit to IN Duration (VIN ≤ 12V) ..Continuous Lead Temperature (soldering, 10s)...+300°C Continuous Power Dissipation (TA = +70°C) Soldering Temperature (reflow) 8-Pin Plastic DIP (derate 9.09mW/°C above +70°C)...727mW 8 PDIP, 8 SOIC..+260°C 8-Pin SO (derate 5.88mW/°C above +70°C)..471mW 8 CDIP..+240°C Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
(VIN = +10V, IOUT = 0mA, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.)
PARAMETER SYMBOL CONDITIONS TA MIN TYP MAX UNITS
Input Voltage Range VIN C, E, M 8 36 V MAX6225A +25°C 2.499 2.500 2.501 Output Voltage VOUT MAX6225B +25°C 2.497 2.500 2.503 V MAX6225AC_A C 1.0 2.0 MAX6225AE_A E 1.5 3.0 Output Voltage Temperature MAX6225AMJA M 2.0 5.0 Coefficient (Note 1) TCVOUT ppm/°C MAX6225BC_A C 2.5 5.0 MAX6225BE_A E 2.5 7.0 MAX6225BMJA M 2.5 8.0 +25°C 10 18 C 30 8V ≤ VIN ≤ 10V E 35 M 45 Line Regulation (Note 2) ΔVOUT / ppm/V ΔVIN +25°C 2 5 C 7 10V ≤ VIN ≤ 36V E 8 M 10 www.maximintegrated.com Maxim Integrated │ 2
