Datasheet TLV9151, TLV9152, TLV9154 (Texas Instruments) - 7
Description | 4.5-MHz, Rail-to-Rail Input/Output, Low Offset Voltage, Low Noise Op Amp |
Pages / Page | 82 / 7 — TLV9151,. TLV9152, TL. V9154. www.ti.com. Figure 5-6. TLV9152S RUG … |
File Format / Size | PDF / 6.5 Mb |
TLV9151,. TLV9152, TL. V9154. www.ti.com. Figure 5-6. TLV9152S RUG Package. 10-Pin X2QFN. (Top View)
TLV9151, TLV9152, TL V9154 www.ti.com
SBOS986E – OCTOBER 2019 – REVISED JANUARY 2022 IN1+ V– 1 9 IN1– 10 SHDN1 2 8 OUT1 SHDN2 3 7 V+ 5 IN2+ 4 6 OUT2 Not to scale IN2–
Figure 5-6. TLV9152S RUG Package 10-Pin X2QFN (Top View) Table 5-4. Pin Functions: TLV9152S PIN I/O DESCRIPTION NAME NO.
+IN A 10 I Noninverting input, channel A +IN B 4 I Noninverting input, channel B –IN A 9 I Inverting input, channel A –IN B 5 I Inverting input, channel B OUT A 8 O Output, channel A OUT B 6 O Output, channel B Shutdown, channel 1: low = amplifier enabled, high = amplifier disabled. See SHDN1 2 I Shutdown for more information. Shutdown, channel 2: low = amplifier enabled, high = amplifier disabled. See SHDN2 3 I Shutdown for more information. V+ 7 — Positive (highest) power supply V– 1 — Negative (lowest) power supply Copyright © 2022 Texas Instruments Incorporated Submit Document Feedback 7 Product Folder Links: TLV9151 TLV9152 TLV9154 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information for Single Channel 6.5 Thermal Information for Dual Channel 6.6 Thermal Information for Quad Channel 6.7 Electrical Characteristics 6.8 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 EMI Rejection 7.3.2 Thermal Protection 7.3.3 Capacitive Load and Stability 7.3.4 Common-Mode Voltage Range 7.3.5 Phase Reversal Protection 7.3.6 Electrical Overstress 7.3.7 Overload Recovery 7.3.8 Typical Specifications and Distributions 7.3.9 Packages With an Exposed Thermal Pad 7.3.10 Shutdown 7.4 Device Functional Modes 8 Application and Implementation 8.1 Application Information 8.2 Typical Applications 8.2.1 Low-Side Current Measurement 8.2.1.1 Design Requirements 8.2.1.2 Detailed Design Procedure 8.2.1.3 Application Curves 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.2 Layout Example 11 Device and Documentation Support 11.1 Device Support 11.1.1 Development Support 11.1.1.1 TINA-TI™ (Free Software Download) 11.1.1.2 TI Precision Designs 11.2 Documentation Support 11.2.1 Related Documentation 11.3 Receiving Notification of Documentation Updates 11.4 Support Resources 11.5 Trademarks 11.6 Electrostatic Discharge Caution 11.7 Glossary 12 Mechanical, Packaging, and Orderable Information
