Datasheet MAX6220 (Analog Devices) - 2
DescriptionLow-Noise, Precision, +2.5V/+4.096V/+5V Voltage Reference
Pages / Page10 / 2 — Low-Noise, Precision, +2.5V/+4.096V/+5V Voltage Reference. ABSOLUTE …
File Format / SizePDF / 791 Kb
Low-Noise, Precision, +2.5V/+4.096V/+5V Voltage Reference. ABSOLUTE MAXIMUM RATINGS. MAX6220
Low-Noise, Precision, +2.5V/+4.096V/+5V Voltage Reference ABSOLUTE MAXIMUM RATINGS MAX6220
(Voltages Referenced to GND) Continuous Power Dissipation (TA = +70°C) IN..-0.3V to +42V 8-Pin SO (derate 5.9mW/°C above +70°C) ..471mW OUT, TRIM ...-0.3V to +12V Operating Temperature Range...-40°C to +125°C NR ..-0.3V to +6V Storage Temperature Range ..-65°C to +150°C OUT Short-Circuit to GND Duration (VIN ≤ 12V)..Continuous Lead Temperature (soldering, 10s)...+300°C OUT Short-Circuit to GND Duration (VIN ≤ 42V) ..5s OUT Short-Circuit to IN Duration (VIN ≤ 12V) ..Continuous
MAX6220
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
ELECTRICAL CHARACTERISTICS—(+2.5V)
(VIN = +10V, IOUT = 0mA, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.)
PARAMETER SYMBOL CONDITIONS TA MIN TYP MAX UNITS
Input Voltage Range VIN 8 40 V Output Voltage VOUT +25°C 2.497 2.500 2.503 V Output Voltage Temperature TCVOUT 2 20 ppm/˚C Coefficient (Note 1) +25°C 2 7 ∆V Line Regulation (Note 2) OUT/ ∆ 8V ≤ VIN ≥ 40V ppm/V VIN 45 +25°C 1 6 Sourcing: 0mA ≤ IOUT ≤ 15mA 15 ∆VOUT/ Load Regulation (Note 2) ∆ ppm/mA IOUT +25°C 1 6 Sinking: -15mA ≤ IOUT ≤ 0mA 30 +25°C 1.8 2.9 Supply Current IIN mA 3.3 Trim-Adjustment Range ∆VOUT (Figure 1) ±15 ±25 mV Turn-On Settling Time tON To ±0.01% of final value 5 µs Output Noise Voltage 0.1Hz ≤ f ≥ 10Hz 1.5 µVp-p eN (Note 3) 10Hz ≤ f ≥ 1kHz 1.3 2.8 µVRMS Temperature Hysteresis (Note 4) 20 ppm Long-Term Stability ∆VOUT ∆t = 1000hr 20 ppm
2 _______________________________________________________________________________________
